which Harmonic Balancer for sbc? big or small? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2006, 05:36 PM
406 ss monte's Avatar
eat a beaver, save a tree
for a internally balanced 406 sbc with a 4340 crank (if it matters), which harmonic balancer would be better? a 6.75" or a 8.00"? i bought a sfi approved 8.00" balancer , but damn that thing is heavy. will the weight of the big balancer hurt anything, or would i be better off with a smaller balancer? any advantages of either?
thanks
Old 03-02-2006, 06:15 PM
tornado-tech's Avatar
I ran into the same issue as my stock-replacement Pioneer balancer slipped on my internally-balanced 408. I went with the TCI 7 1/4" balancer. I looked at all the balancers on the market including 6 3/4" and 8" balancers and decided to go with a 7 1/4" damper to give me a little less weight then the 8" but still provide me with enough balancer mass to control the harmonics of the 3.75 stroke (for my piece of mind). I went with TCI because I have heard horror stories on the Fluidampr plus running in the mud I didn't want any chance of water getting in the balancer due to the elastomer having a pinhole. The lighter and smaller balancer will provide quicker response for your motor to rev along with less weight on the crank snout
hv big block pump for small block roy383ci Engine 9 05-24-2006 06:52 AM
Harmonic Balancer Question FiefSS Engine 22 01-09-2004 08:47 AM
harmonic balancer size... Trav Engine 6 10-07-2003 09:45 PM
Harmonic Balancer nomis30 Engine 7 09-30-2003 03:03 PM
Small Block 400ci...or...Big Block 396ci???? chevyelc81 Engine 17 10-05-2002 07:06 AM
