Harmonic Balancer SBC HELP - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2008, 01:32 PM
Hey just got a quick question here. Honoustly how much difference does one of those expensive aftermarket lightweight harmonic balancers make from a stock GM one. The application is a 383 stroker which will never see over 6000rpm, I am planning on picking up a used stock one but first I want to know if an aftermarket one if worth it or not.
Thanks,
Keith
Old 02-10-2008, 01:41 PM
Jmark's Avatar
Personally, I would not put on a used one. If it's been oil soaked or really old, the outer ring can and sometime does slip some, making timing setting near impossible.
If your engine was balanced, the balancer should have been done along with the rest. If you can swing it, go new, whether stock GM or decent aftermarket.
Old 02-10-2008, 01:52 PM
The rotating assembly has been internally balanced before it was shipped. I didnt get the flexplate or harmonic balancer since they are both neutral weight for 350's and all other internally balanced engines. I will buy a new Gm one I think they can't be too expensive. Thanks.
SBC Harmonic balancer install mr52pickup Engine 7 01-13-2008 10:15 AM
SBC Harmonic balancer - how to fit? Limey Simon Engine 33 05-10-2006 05:32 PM
sbc harmonic balancer 84cutlass Engine 2 04-10-2006 09:38 AM
which Harmonic Balancer for sbc? big or small? 406 ss monte Engine 1 03-02-2006 07:15 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 05:10 PM
