harmonic balancer size... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-05-2003, 03:07 PM
Trav's Avatar
Luv the smell of burnt RICE
i opened up the new harmonic balancer i baught and relized its a bit smaller then mine.. and i don't mean outside diameter.. im talking about the thinkness.. there both 6 3/4 but ones thickness is 1 1/4" and the one on there is 1 3/4".. i don't think it makes a difference.. but wut im worried about is my pulleys.. are they gona be further in towards the motor now?? and won't line up with anything else.. also im running long style water pump.. which is brand new.. so is this the wrong balancer? should i get my money back? or trade it in? the only reason i baught one is because i banged it a bit when i was putting in my gear drive... is there a way to tell if the balancer is still good or if i ruined it? better off gettin my money back for a set push rods or somthin.. thanx for any replys
PS sbc 350
Old 10-05-2003, 03:15 PM
Bumpstick's Avatar
Hammer and a torch
First off the thickness is added by going to the rear of the engine not adding to the front of the balancer... Second and the main issue is never "beat" a harmonic balancer on with anything... There are installation tools for just that purpose, they us a special shaft with different bolt sizes to fit different cranks and utilize a bearing to allow the tool to spin independant from the balancer and not harm anything...
Also the larger the balancer the larger the mass and ability to control the harmonics produced by the rotating assy... If you have either a small cube engine or a balanced assy then you can use a smaller diameter balancer which has less weight... This is the reason for the large balancer with SBC 400`s...
Old 10-05-2003, 03:40 PM
NorthStar's Avatar
Seems to me the 6 3/4" is made for 305 and the 8" are used on 350, the 400 is all by itself.
Old 10-06-2003, 02:19 AM
Some 350's have 6-3/4" ones. 8" ones were generally used on performance engines & trucks. The thin one may be a 305 part or maybe from an older engine.
Old 10-06-2003, 07:00 AM
mav79's Avatar
Blue Jay Racing
Here are a few sizes and what they fit, from the SBC Interchange manual:
6 x 1 3/16 350
6 x 1 11/16 267, 305
8 x 1 350
The 305 "thick" balancers have the timing mark located differently on the balancer, so the timing cover/tab must match to use that balancer. Also, the 305 balancer is slightly hollow, so it doesn't have much more mass than the small 350 balancer.
Hope this helps.
-M
Old 10-06-2003, 07:15 PM
Trav's Avatar
hmm ok.. well wut would be a better balancer for a mild 350 in a full size truck then?? i havent used the one i got yet and i got the receipt to trade it in.. but also im gona have to relocate my my timing tab? should i try this one i baught? wuts the worst that can happen?
Old 10-07-2003, 09:45 PM
Trav's Avatar
anyone?? ok heres another idea.. if anyone has the time to help me all i wana no is on your small block 350 chevy.. can u measure your harmonic balancer width and length? and if your running a long style water pump.. if thats not to much to ask.. i really wana try to figure this out bye the weekend.. be just great when i get it all apart and find out this balancer aint gona work.. thanx again
