harmonic balancer/torsional damper - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-03-2013, 06:36 AM
does anybody know how to tell if a damper is damaged? My 6.25 " nuetral balance Fluid Damper is on my 360 ci SBC after taking a fall off the table, no dents or noticable damage but now the engine has a vibration that comes and goes at all rpms. What is the useful life of a Fluid damper?
Does a side impact to a damper of this type damage it's effectiveness?
Thanks to all,
Roy
Old 03-03-2013, 09:46 AM
LATECH's Avatar
About the only thing I can offer would be to try a different balncer just as a test. Even a stock one should be good enough for you to determine whether or not the issue is a balancer / damper or somewhere else.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
RoyLeoGracie (03-03-2013)
Old 03-03-2013, 10:00 AM
Do you have a Fluid Dampr
or
a Fluid Damper
Fluid Dampers are over seas knock offs, and crank manufacturers do not recommend their use(Eagle, Scat)
The Following User Says Thank You to FmrStrtracer For This Useful Post:
Old 03-03-2013, 10:24 AM
Fluid Dampr
thanks
Old 03-03-2013, 10:25 AM
Thanks for the idea and Nice Poncho!
Old 03-03-2013, 05:43 PM
BOBCRMAN@aol.com's Avatar
My balance guy tells me that the life of a fluid damper deteriorates fast after 3 years.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
RoyLeoGracie (03-04-2013)
Old 03-04-2013, 12:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks to all,
Roy
From a Speedtalk thread Which is the best harmonic damper?:
One thing about a fluid filled damper is that external damage to the case, (hammer blow, mishandling or other incident) can stop the inner ring from moving.
You can contact them to get their advice on it:
Technical Support
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 03-04-2013, 04:14 PM
Thanks to all for you replies.
Roy
Cleaning harmonic damper / balancer Clint Cummins Hotrodding Basics 9 07-27-2011 08:03 AM
machine shop guys-harmonic balancer/damper problem. techron Engine 15 03-21-2008 08:38 PM
harmonic damper ? Blob Engine 4 03-31-2004 03:26 PM
283/327 harmonic balancer /damper Question 59vette Engine 5 11-16-2003 11:42 PM
HARMONIC DAMPER KPI Engine 9 06-14-2002 09:50 AM
