Harmonic Balencer SBC 350 ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 11:35 AM
solidaxel's Avatar
Last journal entry: Project garage complete!
I need to buy a new damper for the 350 SBC that I am working on. The question I have is will the least expensive damper work
any better than a high priced one.
This is in a 1/2 ton pick up street truck. What do you recommend?
What are the downfalls with a cheap damper Vs. a expensive one, who makes the the "right one".
Old 08-30-2009, 11:51 AM
bullheimer's Avatar
NEVER use credit cards!
first off do NOT buy this part from summit!!!
go to local parts store like napa and get the cheapest one they got. i got one from summit a few years ago and had to have the snout milled to line up my pulleys they are about $75
Old 08-30-2009, 03:09 PM
Cheap does not mean quality, and since a lot of CHEAP parts tend to come from overseas, they are not made correctly. An improperly made balancer can lead to bearing and crank failure.
Do some research before buying, just because a part happens to get an SFI rating, doesnt mean it will hold up and protect your motor.
BHJ
FluidDampr(not Fluid Damper)
ATI
TCI
All make quality balancers. BHJ makes several different balancers for stock and racing use. You can always get a balancer from GM also.
Old 08-30-2009, 03:22 PM
ericnova72's Avatar
More for Less Racer
PowerBond also has a good reputation on the engine machinist forums like SpeedTalk for their inexpensive balancers, and suprisingly so does Pioneer. Stay away from Professional Products balancers, many documented failures there.
Old 08-30-2009, 07:17 PM
Well I just got a summit harmonic balancer and it fit just as good as any balancer that I have used. It was around 55 or so and it looks to be of good quality and a little better then the ones you get at the auto parts store like autozone etc. I have a TCI rattler on my other engine but it cost almost 300 bucks but its a very nice built unit. ATI is the best for a elastomer type balancer the fluid ones I have been told by several machine shops to stay away from. They say the best are the elastomer type. I got that from Watson and Rupple performance from Sarahsville Ohio and they did all of my engine machining and they also say good things about powerbond.
Eric
Old 08-30-2009, 08:04 PM
406 bug's Avatar
9.82 @ 139mph
As mentioned, stay clear of fluid type dampers. Summit has an sfi damper that is made in Australia that sells for just over $100 bucks that is a very nice unit. Don't get sucked in by the hype associated with the 300 dollar units unless you plan all out race or just want to impress others.
Old 08-30-2009, 10:57 PM
techinspector1's Avatar
Wiki Edits: 326
Take a look here. These guys have been rebuilding stock dampers for years. They press them apart and intall new elastomeric material under extreme pressure with hydraulic presses while clocking the hub exactly to the inertia ring TDC groove. It's unusual these days to find good quality for a reasonable price, but here it is....
http://www.damperdoctor.com/Merchant...egory_Code=CHE
Old 08-30-2009, 11:35 PM
bullheimer's Avatar
its been since 2001 i got mine from summit, it was made in australia. either it was too long or it ate seals like a killer whale, either way it had to be machined to work. i pitched a ***** to summit, maybe they fixed'em, but i wouldnt buy another one from them anyway. (don't get me wrong, i buy half my stuff from them)
Old 08-30-2009, 11:48 PM
BackYardRacer
if its not going to be any high out put truck just find a good used one off a 305 or 350 same crank its not hard to find good used one around here any way and they are cheap
Old 08-31-2009, 01:04 AM
Wiki Edits: 326
They're cheap because there's a good chance the inertia ring has slipped in relation to the hub, rendering them incapable of providing valid indexing to time the motor with a light. Damper Doctor.
Old 08-31-2009, 06:07 AM
Do not use a 305 balancer on a 350, if you do you will have a vibration.
sam-missle
Old 08-31-2009, 06:32 AM
ericnova72's Avatar
More for Less Racer
sam-missle
BS, its the same balancer. Internal balance SBC.
Old 08-31-2009, 06:50 AM
NO BS, different balancer
sam-missle
Old 08-31-2009, 09:06 AM
ericnova72's Avatar
More for Less Racer
sam-missle
Care to provide part #'s to prove it?? Vibration from changing an internal(or "neutral") balance damper for another neutral balance damper even if they are different weights means something is wrong with the balancer or the crank, but they are interchangable, from 262 thru 350 cubes, the 400 is the only SBC oddball.
Next you are going to tell me the flexplates are different too . I'm not talking about 2-piece seal vs 1-piece seal either, that is a different issue.
Old 08-31-2009, 10:35 AM
bullheimer's Avatar
maybe he's talking @ diameters. go with the 8" if you can miss your timing pointer.
305 head on a 350 sbc Trav Engine 41 04-13-2013 08:30 AM
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
0.060 over 350 sbc or 0.040 over 400 splayed cap sbc tony350ss Engine 4 05-17-2003 09:02 PM
