Harmonic balnacer Weight - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2010, 10:39 AM
hey guys,
i have a chevy 350cid, im rebuilding the top end and the balancer i took off is an 8inch, it weighs 12lbs (internal balance i think, i dont see any weights in the balancer). my question is the new one is 6.75 and only weighs 8lbs., ati suggested the balancer to me, but the weight and size thing seems odd to me(it being so different). does the new one sound right? any help would be great, Thanks
Old 07-26-2010, 11:02 AM
DoubleVision's Avatar
I would get a stock replacement 8 inch balancer. If your engine is street bound then that`s all it needs.
Old 07-26-2010, 02:21 PM
lg1969's Avatar
Google "Tunnel Ram 406"
I would not worry about it. Use the 6.75" balancer All sbc motors are internally balanced with exception 400sbc. There is notch on the corner almost half way around the balancer on a 400.
Old 07-26-2010, 03:02 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 65malibuSS
hey guys,
It depends on how the engine is used, and what parts make up the reciprocating assembly. If it's going to be run hard and/or raced- unless it's an all-out, drag-only engine- I would use the 8" damper.
Actually, I use the big dampers whenever possible. The 302 Z/28 and the LT-1 SBC used 8" dampers. The externally balanced 400 damper is 8". A small damper might be a good choice for just drag racing or for smaller displacement engines, relatively lower output engines and engines used sedately.
Well, sort of. The 1-piece RMS engines use an externally balanced flexplate or flywheel, but w/a neutral balance damper. Kind of "half and half".
Old 07-26-2010, 03:51 PM
The ATI damper is much superior to a stock bonded type damper, so size-only comparisons are not valid. The damper's function is to counteract crankshaft torsional twisting forces with a counter-force to minimize crank fatigue. Therefore, the dampers effectiveness varies with the RPM of operation, the amount of weight available for imparting the counter-force, and the type of suspension of the weight on the crank.
Unless you are building a school bus engine, use the ATI.
The D.O.T. gonna gitcha. coldknock Hotrodders' Lounge 32 10-31-2007 06:33 AM
Harmonic balancers - extra weight? crossy Engine 11 02-18-2007 01:21 PM
External/Internal balancing ap72 Engine 22 04-29-2006 10:25 PM
tryin to figure out the weight of truck 5.7s10 Hotrodding Basics 6 01-14-2006 08:40 AM
Best Rust Inhibitor? bigbrowndog Body - Exterior 45 11-21-2004 08:26 PM
