Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HARMONIC DAMPER
Old 06-11-2002, 06:01 PM
Studebaker Studebaker is offline
The vibration dampner to crankshaft snout is a machined interference fit. Do you have a dampner installation tool? The end of the Crankshaft is threaded for the retaining bolt. A dampner intall tool threads into this hole and allows you to press the dampner on the Crank snout. Also make sure there are no Burrs on the crank, dampner or indexing keys. Good Luck.
