Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HARMONIC DAMPER
Thread: HARMONIC DAMPER
Old 06-14-2002, 10:50 AM
bullheimer's Avatar
bullheimer bullheimer is offline
NEVER use credit cards!
Post
thought i replied already but where'd it go? definitely heat the damper. use potholders to take it out and pound it on with a big-*** block. i used a 8x8 about a foot long. check clearance with a plastigage before you keep beating the **** out of it like i did, because i had to machine some of the snout off. if you bought it or it came from summit, it will have to go to the machine shop anyway, because their snouts are too rough to use and will eat the seal right up!! put the water pump pulley on and then liine up the balancer pulleys before you go machining the end off.
