I would have to say yes you need a new one because the engine in my truck has been rebuilt but the damper has shifted, don't know if the outer band slipped, or it slipped on the crank, but both can happen.
A stock rebuild will not require a new balancer. THE OLD 283's had more of a hub than a true balancer. If you do decide to use a new balancer the smaller of the two mentioned will do just fine. Just get matching timing tab and be prepared to modify or remove the old welded on tab.
Probably not, they just have to cover their donkey! These are all made across the pond now days and some are questionable quality. They all seem to be too small ID wise. We usually have to hone them a bit to fit. We were getting a few split ones from customers that tried to fit them right out of the box.
If you are going to buzz that 83, you better drill and tap the crank for a bolt! A balancer car do moocho damage leaving the scene at 6000 rpm. |
