Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Harmonic Vibration
Old 08-09-2011, 11:23 AM
KMatch KMatch is offline
There is no 1 size fits all. You need to measure the angle at the rear of the transmission of engine tilt. If it's 3 degrees, the pinion must be tilted up 3 degrees. 2 for 2, and so on and some will be good with a degree or so of difference and others, not so much. Another thing, never run a driveshaft at zero degrees at either end (driveshaft straight) - this will kill u-joints as the needles will pound grooves in everything.
