Harmonic Vibration - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2011, 04:46 AM
"Stranded, but not abandoned"
Harmonic Vibration
What's the correct pinion angle for a 9" Ford rearend?
My '53 Chevy 3600 had a 9" Ford offset rear end and a two piece driveshaft. It ran pretty smooth at that time.
While doing a frame-off restoration, I decided to convert to a single piece driveshaft and set the rearend angle more in line with the driveshaft. Converting to a single piece driveshaft and resetting the pinion angle to 3 degrees has resulted in a bad harmonic that starts about 35 mph and increases with speed.
Help.
Old 08-09-2011, 09:50 AM
S10xGN's Avatar
Gotta love a turbo!
U-joints are designed to handle some amount of misalignment. Do you trust whoever built the driveshaft? I'd start by verifying the phase angles, both sets of "ears" should be in exactly the same plane...
Russ
Old 08-09-2011, 12:23 PM
There is no 1 size fits all. You need to measure the angle at the rear of the transmission of engine tilt. If it's 3 degrees, the pinion must be tilted up 3 degrees. 2 for 2, and so on and some will be good with a degree or so of difference and others, not so much. Another thing, never run a driveshaft at zero degrees at either end (driveshaft straight) - this will kill u-joints as the needles will pound grooves in everything.
Old 08-20-2011, 01:56 AM
harmonic vibration
Well, it looks like the pinion ange is 3/3, but 3 down and another 3 down--ugh. The front u-joint is slinging grease and is fighting back. I've only been able to drive it at 20-30 mph thus far. The body work looks good, but...
Old 08-20-2011, 09:55 AM
S10xGN's Avatar
Gotta love a turbo!
That could be your problem. When I built my Maverick, my "cohorts" told me to weld the spring perches with the nose at 6 down because of the leaf springs. Obviously, they are racers and not street drivers. After realizing that my Caltrac bars don't allow any pinion rise, I ordered a set of 8 shims (from an offroad place) to counteract my negative pinion angle. I now have my trans at 4 down and the pinion at 2 up, and all is good!
Russ
vibration????? 350olds Engine 1 03-06-2007 10:55 PM
Driveline Vibration caused by Harmonic Balancer!! 71gtx Engine 1 06-03-2005 01:09 PM
Have an odd vibration...need some help 357ford Transmission - Rearend 8 11-14-2004 09:09 AM
engine vibration / harmonic balancer briansansone Engine 4 11-01-2004 10:29 PM
Vibration rickss Engine 19 02-13-2003 12:49 PM
