Harness help.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-04-2004, 05:00 PM
Harness help..
I have 2 projects that will need harnesses, I have wired my own before but it just isn't as clean as a kit with labeled wires. I have heard that painless really isn't that great and when I flip through the zines I find TONS of companies making kits..
So what's the concensus on these things?
BTW one is for a 57 chevy wagon (4 door)
one is for a 63 Scout (off road toy so add winch, cb, lots of other accessories)
Old 11-04-2004, 05:55 PM
Restorer/Builder
Last journal entry: 48 Grille Swap 3
I like EZ-Wire harnesses...about $100.00 cheaper than Painless.
Old 11-05-2004, 02:06 PM
MI2600's Avatar
Member# 3287
I've tried M&H and found their products to be very good:
www.wiringharness.com
Also, you didn't state which harness(es) you needed...dash, charging, engine.
Old 11-05-2004, 02:25 PM
complete harness, not engine though - it has it's own harness. Something with an 18 circuit fuse block.
kinda funny, that place doesn't even recomend themself..
Where can I get a harness for my Street Rod or Roadster or Race Car?
For Race Cars, Roadsters, Street Rods and Custom Wire kits we recommend American Auto Wire. There extensive line of do-it-yourself kits are the best we've seen. They can be reached at (800) 482-WIRE.
A little pricey but this looks good for my 57
http://www.americanautowire.com/Products/cup.htm
Something pretty universal using would work fine for my Scout
I wonder how the "summitracing" ones are..
Old 11-05-2004, 09:30 PM
EBlack36's Avatar
Rebuilt Excitment
I used an EZ Wire system in my 57 Chevy 210 4 door wagon and it works great. It is a 21 circuit unit and they now run around 160.00. You do need a separate unit for the engine, the one unit takes car of it. I have installed 4 or 5 of these now and they are very easy for the novice, we did the 57 in a day and a half from the headlights to the taillights.
Old 11-06-2004, 12:08 AM
Dutchman's Avatar
Old Salt
Take a look at Horvaths webpage. He documented his whole wiring process. I think he used EZ.
I'm still building my 37 Dodge business coupe...and now I'm finishing up a painless/not wiring harness. Tazz
Tazz had to get some professional help with the Painless wiring.
Dutch
Old 11-08-2004, 12:11 PM
I'm looking at the centech but I'll check out the EZ before I buy one..
Old 11-08-2004, 09:07 PM
curly5759's Avatar
I used American Auto wire in my 59 chevy truck, and I am currently using (still installing) a painless wire kit in a 41 Cad street rod.
I had always heard good things about painless, but I'm not impressed. The quality of the wires is ok, as well as the fuse box, but the wiring instructions leave a lot to be desired. American autowire gave a complete schematic of the entire harness, had disconnects for each differnent harness (engine, dash, rear lights , etc) Overall, a much nicer set up. I wish I had spent a little more money and gotten a better kit.
