has any one used pvs pipes for air supply - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-31-2011, 10:57 AM
life is a temporary assignment
Originally Posted by oldred
1/2" is plenty big enough to get someone hurt, it does not have to be 2" and I was only guessing at that size anyway because I agree that it would take a lot more volume than carried by a normal shop sized pipe to blow a hole in the ground that big. The point is that these pipes can and do rupture from any number of causes and when they do it can be catastrophic, 90 PSI in a 1/2" line is more than enough to cause serious injury. One incident I read about back in the 80's involved an eye injury when a guy bumped a PVC line with with a welding tank cart and another was when someone hit one with a fork lift. Arguing these accidents should not have happened in the first place and the lines should not have been in those locations is pointless because unless a PVC line is inside a shielding conduit (considered safe to do it that way BTW) then any number of unforeseen circumstances can occur. It's a fact that even a blow light enough to only dent copper line and not even scratch iron pipe could easily cause a situation like that ridiculous gunshot incident. The welding cart would have been an unnoticed non-incident and the forklift might have been a leak but neither would have been the injury causing accidents they were because of the PVC. Also PVC does not need a blow from a sharp (or even blunt) object to rupture and often the rupture is not at first apparent, age or deterioration from any of several common contaminants (or sunlight) can cause a PVC pipe to rupture without warning. Pointing to an old PVC setup as proof of safety is no different than pointing at a ninety year old smoker as proof that cigarettes are harmless, beating the odds is not proof something is safe.
I agree with you oldred... But isn't 90 % of the things we do everyday unsafe..Like cutting aluminum with circular saw,, It is unsafe,, But is done everyday... Riding down the road everyday is really unsafe,, Like using a cut off wheel on a grinder,, And so on.... The results from using pvc pipe is the same good and bad on anything... Am I saying to use it... NOT AT ALL !!!! But it has been done for years with good results as well as bad ones.... Kind of like driving your car.... It has to be done with commend sense..
Like anything..We do everyday...That's the only thing I can say on this..
Use what you want to.. But ''ALWAYS'' remember there can be a dangerous side to it..
There is a dangerous side to EVERYTHING...
  #32 (permalink)
Old 08-31-2011, 10:58 AM
I haven't read every word in the thread so forgive me if I repeat but the possibilility of failure isn't the only reason not to use PVC, it retains heat. You want your air to cool off so the water trap can do it's job.
And someone mentioned black iron pipe, NO, black iron is for gases without moisture. You want galvanized pipe, or copper of course.
I did my garage in galvanized in one afternoon, done deal never have to think about it it again, EVER.
  #33 (permalink)
Old 08-31-2011, 11:05 AM
You keep picking at me and trying to start something for whatever reason but I worked with air lines for many years and I know what can happen whether you are smart enough to see it or not. If someone wants to disagree with the PVC safety issue and discuss it then fine but if you have a personal vendetta against me for some reason you are perfectly welcome to take it to a PM but leave your childish attitude out of what could be a serious safety issue!
Get real Oldred... If I had something against you... You would be the first to know it.... And I wouldn't do it in front of anyone... Now calling me childish.. That's a Act against me.... I think I have every right to say what does work in what doesn't also... I said: ''IT ISN'T SAFE''... Didn't you see that...
As far as the winning against you comment..I have learn in the pass that a lot of times it only your way.... Are is that your way of showing you have something against me???
  #34 (permalink)
Old 08-31-2011, 11:12 AM
shine's Avatar
SPI Thug
Last journal entry: some progress
there is a new plastic out that i am going to look into. depending on price i may replumb this winter. i believe a very big factor is pressure. even my 15 horse compressor at the van shop was set low. i had no doubt that thing would explode pipes. all i'm saying is it can be used safely if you pay attention and do it right. mine is run so it is protected , i run less than 90 lbs of pressure . i would love to do my shop in copper but the price is ridiculous. we're talking over a couple hundred feet of copper. we'll see what this new stuff is and the cost.
i promise red if mine blows and puts a splinter in my butt i will sell a cow to buy copper.....
  #35 (permalink)
Old 08-31-2011, 11:15 AM
Shine, copper isn't expensive at all! It isn't as cheap as PVC (pvc is damn near free!) but it isn't like brass pipe, now THAT is some expensive stuff! I did a short 18" section with a few elbows and it was $65!
But copper would only cost you $250-300 with all the fittings!
  #36 (permalink)
Old 08-31-2011, 11:21 AM
shine's Avatar
SPI Thug
i am getting the info on rapidair system. 100 ft kit is 139.00 . looks interesting.
anyone use it, heard of it , like it , hate it. any other suggestions. copper is out of the plan here.
  #37 (permalink)
Old 08-31-2011, 11:23 AM
I was thinking of giving this stuff a try..
Does anyone know anything about it..
Same thing shine..Just a little cheaper..
http://www.google.com/products/catal...d=0CHIQ8wIwAA#
  #38 (permalink)
Old 08-31-2011, 11:28 AM
shine's Avatar
SPI Thug
copper is around a 1.50 a ft here plus fittings. the 100 ft kit comes with 2 outlests with drains and a manifold . not a bad price.
  #39 (permalink)
Old 08-31-2011, 11:42 AM
It won't do anything for your moisture problem
  #40 (permalink)
Old 08-31-2011, 11:43 AM
Have you used it ???
  #41 (permalink)
Old 08-31-2011, 11:44 AM
shine's Avatar
SPI Thug
explain it to me , i'm kinda new at this.
  #42 (permalink)
Old 08-31-2011, 11:46 AM
No, I haven't used it, but my common sense tells me that it won't cool like metal.
  #43 (permalink)
Old 08-31-2011, 11:47 AM
Metal also sweat's..And I'm not trying to be a smart a** here... I'm also trying to learn something...
  #44 (permalink)
Old 08-31-2011, 11:50 AM
I seriously doubt that you could cool the air inside of the pipe enough that the outside air temperature would make it sweat.
  #45 (permalink)
Old 08-31-2011, 11:52 AM
You have to keep in mind that you are not running cold underground water in the pipe, its warm air from the compressor.
air supply MIKE1954 Introduce Yourself 3 12-23-2005 07:19 PM
Hvlp Air Supply Kampr Body - Exterior 11 09-16-2005 11:47 AM
air supply settings handyman Body - Exterior 11 09-10-2004 12:22 AM
Fresh Air Supply Dasoldier Body - Exterior 8 03-23-2004 10:52 AM
