has any one used pvs pipes for air supply - Page 4 - Hot Rod Forum : Hotrodders Bulletin Board
  #46 (permalink)
Old 08-31-2011, 10:52 AM
NEW INTERIORS's Avatar
Set no limit's on yourself
Originally Posted by Chevymon
I seriously doubt that you could cool the air inside of the pipe enough that the outside air temperature would make it sweat.
I guess your right about that..
  #47 (permalink)
Old 08-31-2011, 10:55 AM
shine's Avatar
Last journal entry: some progress
you cool and remove moisture BEFORE you send it through the lines. using copper is not going to solve a water problem nor will plastic create one.
  #48 (permalink)
Old 08-31-2011, 10:57 AM
That's what I always thought..
  #49 (permalink)
How are you cooling your air?
  #50 (permalink)
Old 08-31-2011, 11:00 AM
What I was getting at about the metal lines was, I don't leave air pressure on my lines when I'm not using them... Wouldn't the metal lines sweat with nothing in them on a very hot day..
  #51 (permalink)
Old 08-31-2011, 11:09 AM
I live in Michigan and have my compressor upstairs and run 3/4 inch galvanized pipe for about 30 feet of unheated areas of my building before entering the shop. And there is about 60 feet of 1/2 inch galvanized pipe in the shop and I have never seen any moisture on the pipe.
  #52 (permalink)
Old 08-31-2011, 11:17 AM
In order for the pipe to sweat, the temperature of the pipe has to get below the dew point. That would be rare in air pipes, if it is possible. IMO I hope someone corrects me if I am wrong.
  #53 (permalink)
Old 08-31-2011, 11:23 AM
I have been reading some of Hub's old posts about compressed air, maybe you guys might find it interesting.
http://www.asetusa.com/phpBB3/viewfo...daba1ce6ea4a2e
  #54 (permalink)
Old 08-31-2011, 11:24 AM
Shine again you have me puzzled? How are you cooling your air at the compressor? Copper is the very best way to cool the air and remove moisture and PVC is a terrible choice for that purpose. Assuming a person does not have a cooler of some sort located between the compressor tank and the supply line then the line itself from the tank to the water separator is expected to serve as the condenser for the water vapor, that's the reason 50' of pipe is the recommended minimum. Basically what the pipe does is cool the hot air as it exits the compressor tank, hot air will contain the moisture as a vapor which will pass right through a water separator. The idea is to cool the air by using the metal pipe walls to radiate off the heat therefore causing the water vapor to condense and collect on the cooler pipe walls so that the separator can remove it, this is why a water separator does not do much good if it is mounted close to the compressor tank. Pipe does not "sweat" as is commonly said but the water is condensed out of the air when the heat is radiated off and the water vapor turns into liquid which is what you want it to do. Once the water has condensed into liquid and collected on the pipe walls it can be drained off into "drops" or collection points where it can be later drained out of the system, likewise the water that is still in the air flow will now be condensed into liquid droplets that can be more easily collected in the separator. Nothing much like this happens when using PVC, the PVC is very inefficient at removing the heat so the air will stay hotter and more of the moisture will remain in vapor form to pass through the separator and into your air lines. Once this vapor is past the separator some of it will condense in the air line and exit into your tools as liquid water while some of it will condense as the air cools from expansion upon exiting the hose. So yes Copper vs PVC can and does make a profound difference in the amount of water that can be easily removed from an air system before the air reaches the tool being used., this is not just opinion but a well known engineering fact.
  #55 (permalink)
Old 08-31-2011, 11:30 AM
Shine I know you are having moisture problems and need dry air for blasting. Tell us what you have now.
  #56 (permalink)
Old 08-31-2011, 11:36 AM
I actually doubt that he does, Shine is a pro and would never put up with a problem like that. I don't know what the humidity is like in that part of Texas but humidity makes all the difference.
Shine do you use a cooler on that system?
  #57 (permalink)
Old 08-31-2011, 11:41 AM
Be nice Red, they are convinced, and I think they could use a little help. Shine is off line now.
  #58 (permalink)
Old 08-31-2011, 11:50 AM
Actually the first water trap (or outlet) should be at 25' from compressor. At that point the air should be cooled off enough for the water droplets to be large enough for the water trap to trap it.
  #59 (permalink)
Old 08-31-2011, 11:54 AM
Not sure what you mean but I was not being sarcastic, I have known Shine for a while and he really is a professional who could not put up with a moisture problem. I am certain he does not have one but I don't know how his system is set up so I am curious how he accomplishes this.
  #60 (permalink)
Old 08-31-2011, 12:02 PM
Sorry if I misread your comment intent. I saw a post from shine on another forum, and he was talking about running pipe underground soon, so I think that means he is having trouble. And with the blasting that he does, it could be very aggravating.
He shares so much, it would be nice for him to recieve once in awhile, nobody knows it all. But if he is reading the comments from Hub, it should put him in the right direction.
air supply MIKE1954 Introduce Yourself 3 12-23-2005 06:19 PM
Hvlp Air Supply Kampr Body - Exterior 11 09-16-2005 10:47 AM
air supply settings handyman Body - Exterior 11 09-09-2004 11:22 PM
Fresh Air Supply Dasoldier Body - Exterior 8 03-23-2004 09:52 AM
