Has anyone adapted a Mopar trans to Chevy engine? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2009, 02:53 PM
383ram's Avatar
Last wiki edit: Wheelbase, track width, and differential measureme...
Last journal entry: Upper P/S bracket made
Ok, Here is the deal. On my quest to stick a 383 SB Chevy engine in my '85 Ram, i have had to choose a transmission. Now my initial thoughts of a TH350 or 700R4 are what i was to this point looking at.....
Option 1. I really wanted a stick trans (truck has the pedals i installed a couple years ago.). While not ideal ratios, i always liked the overdrive 4-speed 833 trans for use----it actually wouldnt be to far off from a 700r4 trans. Now it seems to me, if i bought a steel bellhousing (scattershield) for the Chevy, i could either drill/tap new mounting holes or weld a plate onto the bell for adaptation of the Chrysler trans. Also seem to recall someone actually made a specific bellhousing for just a swap. Clutch linkage would be easy enough to fab, but im willing to bet most of the Chrysler stuff would bolt right in. I haven't looked, but i assume a 400 SB chevy flywheel is readily available and fairly inexpensive---(compared to $250-350 for a mopar flywheel).
Option 2. Chrysler 904 automatic. Just for kicks, if any of you ever looked at a Chrysler trans VS a GM trans, i think you might be shocked at the beefiness of the Chrysler. Now i am by no means a trans genius, but i have built more than a few Chrysler trans when i worked in the dealership and on the side. I personally think they are way easy to build compared to what i have seen from GM---but i guess thats debatable.
So how do you get a Mopar auto to a GM engine? Well, my idea---again using a steel scattershield-- is to follow what JW performance trans did and replace the front "bell housing" area on the trans with an adapter made from a scattershield. For those of you not familier with the process, the trans is cut even with the front pump, and the "shield" is bolted to the front of the pump using a little longer bolt. Unfortunatly, JW makes an adapter for almost any combo except what i want to do. And any adapter i Have actually found is almost $500. But really, once the depth is right for the converter, why wouldnt it work? Seems to me you can drill a new pattern in the flexplate to bolt the 4 bolt Chrysler converter to.
So what do you say, i dont see any real drawbacks of what i want to do, just keeping everything measured properly, and centered for runout would seem most important.
Old 03-08-2009, 03:23 PM
Crazy Mopar Guy's Avatar
You could buy a 1985 Chevy truck with a blown engine for less money than all the pieces to swap are involved I'm willing to bet.
AND you could resell the 1985 Chevy truck more easily as well with a SBC in it.
Old 03-08-2009, 03:42 PM
82 to 87 Chevy trucks were available with a T833, Chevy bolt pattern, that will bolt right up.
Old 03-08-2009, 04:23 PM
383ram's Avatar
Where is the fun in that---you must be one of those purists. What about some old fashioned hotrod engineering?
I have measured up a 700r4 and 350, and along with the engine, they will pretty much endup in the same space as the stock mopar stuff---just whip up a few mounts and good to go. Infact, if i do go with the 700r4, i can use the engine and trans chrysler isolators to boot, and not cut the stock driveshaft.
Well now, i did not know that. That would certianly make things easy if all else was equal on lengths and what not. I'll have to see if i can find one of those.
Old 03-08-2009, 04:26 PM
Wiki Edits: 85
Chrysler actually made an automatic transmission that has a CHEVROLET bell and DIRECTLY bolts to any motor that has a Chevrolet bolt pattern. They are found in some AMC and JEEP products behind 4 cylinder motors. However the same transmission (with a different case) was also used with 360cid Chrysler motors so there are lots of parts available to upgrade from a light duty 4cyl version to a beefier V8 version. You may need a custom built converter as I don't think a normal V8 converter will fit the bell or flex plate.
Best bet is to find the 4cyl first, then find a V8 about the same year and swap parts. Since you have built lots of 904s in the past, this should be a snap for you.
Old 03-08-2009, 04:34 PM
383ram's Avatar
Holy cr_p, you mean there is a case out there like i am imagining? Yes, internal swapage of parts SHOULD be a snap--providing chrysler still followed the rules and never changed basic parts. The 383 i am building is a low rpm motor emphising torque and midrange---just like stock---but alot more.
Old 03-08-2009, 04:44 PM
Wiki Edits: 85
Chrysler never changed much in the 904s except for updates, so most parts in any given year bracket will fit any 904 with the proper TLC.
The pump is 6-1/4" long compared to the normal 6-3/8" from the late 60s up (6-1/2" in early 60s). Input has 23 splines instead of the "normal" 26 or 27. Pretty much everything else is normal 904.
Found in 1980-1983 AMC/JEEP products.
Old 03-08-2009, 04:50 PM
383ram's Avatar
Would that be in the 2.5 4 cyl jeeps?
Old 03-08-2009, 04:54 PM
Wiki Edits: 85
Yes, 151L4-25 engines.
Link to more info: http://en.wikipedia.org/wiki/List_of...using_patterns
Old 03-08-2009, 05:39 PM
383ram's Avatar
Thanks for the info. Now just need to way my options.
Obviously they lightend the capacity for the 4 cyl jeep as far as spline count and whatnot on the front pump. So i'd be unsure on the strength---remember the early 700r4's? I also would imagine i would HAVE to use that converter too, Which may stall higher behind a 383---not sure on size or specs----but it seems it would drop into the v-8 as far fitment as the snout on the chevy converter is about .100" smaller than the true chrysler one--provided the 2.5 used the same crank pilot size as its bigger v8 siblings.
Old 03-08-2009, 06:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
quite true on the chevy bell on the 904 mopar trans
here is a photo from my gallery of the 904 Mopar transmittin
Old 03-08-2009, 06:12 PM
383ram's Avatar
Crosley, do you know if the smaller splines on the pump as far as strength will be any issue and if the converter would definatly bolt up to the v-8 and flexplate?
Old 03-08-2009, 06:48 PM
Wiki Edits: 31
AMC used GM 4cyl's in the early 80's... you would have to get a pre '86 Jeep/ AMC 2.5L trans ( IIRC they made there own for '87, same year the 4.0 came out) as that will be the Chevy bell...
Of course, if it were mine, I would find a Mopar 383 or 440 big block, and use that.. cause with mounts from a 440 powered truck from the 70's, it'll bolt right into your truck..
Old 03-08-2009, 07:01 PM
Nope, just trying to steer you down the "logical" path and save you money.
Unless you absolutely LOVE the looks of a 1985 Dodge truck, which is what starts MOST "hotrod engineering" projects....
Good luck!
Old 03-09-2009, 07:02 AM
SSedan64's Avatar
Are these the 60* or 90* Chevy bell pattern?
350 Chevy Issues engine trouble... Please help me! ineedspeed Engine 26 07-28-2008 04:23 AM
Chevy big block engine knock Ratillac51 Engine 3 01-07-2007 03:33 PM
6" Rods in a 400 Blazin72 Engine 19 12-23-2006 09:04 PM
Chevy 350 Engine & Trans in a 46 Chevy Pickup Warner Engine 4 02-11-2005 04:44 PM
need Chevy truck engine decode info pre - 1954 khardy Engine 1 12-07-2004 06:16 PM
