Has anyone ever heard of EnValve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-26-2004, 11:39 AM
mustangdude947's Avatar
Resident Jury-Rig Expert
I was looking on the internet and I found this interesting product: http://www.envalve.com/
Anyone ever heard of or used it before? It seems pretty cool...
Thanks,
Tony
Old 09-26-2004, 12:49 PM
4 Jaw Chuck's Avatar
If you have so much blowby it needs a rebuild not a $20 PCV valve.
— Han Solo
Old 08-03-2005, 09:35 AM
Envalve
Yes...I know everything about the envalve.
dautorio
Old 08-03-2005, 03:21 PM
acr acr is offline
Dautorio.... And?????......
Old 08-03-2005, 03:35 PM
FEDDO's Avatar
envalve
Next question would be ,What is it?.
Old 08-03-2005, 05:40 PM
Jmark's Avatar
I sure hope the valve works better then their web site, its dead! LOL
Old 12-01-2005, 06:18 AM
I installed an envalve on a 1989 Jeep Wrangler that had enough back pressure in the crank case it was blowing oil from just about every seal and grommet in the engine. It even blew out the dip stick when going down the interstate. The envalve fixed the problem. Plus the guy that runs the site "Emil" was very helpful in troble shooting my installation problem I had. Hope this helps.
Old 12-01-2005, 09:27 AM
MI2600's Avatar
Member# 3287
My attempt at the link "was refused".
Old 12-01-2005, 09:36 AM
71 c-10's Avatar
just a kid and his truck
mine as well, and to hawkiwg jeeps have a very common problem with the PCV valve and circuit not functioning properly and either sucking oil and drenching the air filter, or causing excess pressure, its important to change your pcv at about every 30k, its not one of those use it for life kind of deals...
Old 12-01-2005, 01:00 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
The PCV problem with Jeeps is mostly with the 4.0L. It has a very small tube for PCV and really no valve -- just a baffle in the valve cover. The plastic tube gets clogges and causes a problem. Best to replace the tube and remove the valve cover to clean the baffle.
