Has anyone ever seen a hotrodded GMC V6 or V12? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2005, 10:44 AM
Just curious if anyone has ever seen a hot rodded GMC V6/V12. The V12 had up to 672 ci. Basically it was two V6 GMC's cast together end to end.
I always thought this was a neat looking motor. Usually see them in 1960's GMC trucks. The valve covers are shaped more like a small block Ford. The spark plugs enter at the top of the head as if it were through the intake. Distributer is in the back. It looks more like a Ford than a GM product.
Old 08-26-2005, 12:14 PM
Bumpstick's Avatar
Hammer and a torch
Was called and odd fire V6 lots of torque but basicly a Dino motor... (should have been used in tractors)
Old 09-19-2005, 03:46 PM
I know I've seen them in oil fields and in old large GMC trucks.
Old 09-19-2005, 05:21 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
A few years ago I had a 63 GMC 3/4 ton pickup, it had a 305 V6 with a 4.10 Dana 60. The engine was great for torque, but low rpms, at 65 mph it sounded like the engine wanted out from under the hood. More than once I had it loaded to the gills taking junk to the landfill, it would walk up some pretty steep hills with out straining.
As for a Hot Rod, I don't think so.
Old 09-19-2005, 11:48 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Saw/heard one of those GMC 350 cube V-6 blow up in a school bus one afternoon on the way home from school in 63.... What a noise and smoke show... yyyyyyyeeeehhhhaaaaawwwww. Ya, he was "hotrodding it" for all it would do against the governor...... I bet she was doing 3800 rpm when she let go......
Old 09-20-2005, 02:31 AM
Pony's Avatar
The 305 V6 was a heavy duty bus/truck motor that found it's way into some pick up trucks due to an engine shortage at the factory. I had a 63 with a 2 speed powerglide in it for a dump run truck. It was dependable but what a pig. It would shift at about 15mph and labor all the way up to 50mph using a ton of gas on the way. In the few years we had it, it met a log truck on a narrow bridge and both sides lost, went froward over an embankment, backward over and inbakment, hit a tree in the front and hit a tree stump in reverse, (lots of snow and black ice without a posi). The only spot not damaged when we got rid of it was the roof and it still ran like a top.
Old 09-20-2005, 07:11 AM
A few years ago I ws getting this restoration magazinw for a year. They just happened to have an article in one issue about the GMC 305 V6. What they claimed was that the engine used different sized pistons depending on what cylinder # it was! I can't verify this and thought it was strange. If this is true, can you imagine trying to get a set of slugs for it.
Old 09-20-2005, 08:56 AM
How about a roadster big enough for Shaq. They are going to use a 702 ci V12. built from a Peterbuilt cab and nose.
http://www.blastolene.com/Work_in_Progress/
Here's a good shot of one of the motors. Other than for restoring an old truck or just for the bragging rights of claiming a 702 ci V12, sounds like a poor choice for a rod.
GMC 702ci V12
Old 03-08-2009, 10:35 AM
V12 hotrod
Run with it!
http://thunderv12.com/
Old 03-08-2009, 10:45 AM
Actually, it was 702 cu in.
Old 04-20-2009, 11:28 PM
Last journal entry: pistons
yes actually its mine and im currently building parts for it. Here is my forum page for my intake manifold build take a look
Old 01-09-2010, 11:08 AM
gow589's Avatar
the Clever Turn Signal
Originally Posted by hardway
You can purchase the GMC V12 there at various levels ready to run.
Old 04-10-2011, 07:28 PM
Last wiki edit: Building a GMC 702 V-12
Wiki Edits: 44
702 V-12 Builders?
So who is building a GMC V-12 project? With the price of gas you want to be sure to be 70 MPH at 1200 RPM. I am building one and do have a great deal of knowledge on "hot_rodding" one of these. Right now the biggest limitation from what others say and I can see are the exhaust passages in the heads. Nothing aftermarket for these babies so you need to seek out their magnum versions. Hens' teeth to say the least. As you can see by visiting Bob's Thunder V12 site, you can push over 5000 rpm BUT there are a good number of tricks to pay attention to or it is going to die a horrible death supposedly between 3000 and 4000 RPM. Both killers relate to oil system. Oil pump cavitation and journal clearances.... be sure to address them.
So.... OD that can handle 1000 ftlbs of torque? I and going to start with a capable tranny but right now I have an old Brownie (Lipe I think) that looks like it will grenade compared to the tranny (Fuller RTO 910). Anyone got any recommendations?
Old 04-11-2011, 12:06 AM
CJ_1080's Avatar
known to do dumb stuff!!
What about an Allison? I know of an Allison that survives many pulling seasons behind a duramax making 975 HP and something like 1600 foot lbs. Or so I was told. Either way it is well over 1000 ft lbs!! Something to think about!
Old 04-11-2011, 01:03 AM
The V12 is very heavy, has low compression, does not like to rev, and is rated at only 250Hp.
As already said, the heads and manifolds are not wonderful, and making it breathe well at much higher revs will be both difficult and expensive.
But.... A couple of turbos on the V6, or four turbos on the V12 would be magic.
The low end torque is already there, but even very low boost pressure would really build some serious power potential, and the engine is easily strong enough to handle some boost just as it is.
Big strong lazy low reving truck and marine engines make killer turbo engines.
1957? GMC truck impala59 General Rodding Tech 22 04-07-2012 06:29 PM
V6 to V8 mini van ? bowtieorbust Engine 13 01-16-2004 08:27 PM
1954 GMC V6 3 speed on the floor swap out Flaming54 Engine 3 10-16-2003 06:02 PM
DOHC 3.0L V6 in 1990 Ford Probe? Alabama Man Engine 5 01-26-2003 12:01 PM
