Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Has anyone got torque specs for installing the 4l60e+....
Old 05-20-2011, 02:12 PM
tnsmith10's Avatar
tnsmith10 tnsmith10 is offline
when will it rain???
Originally Posted by old yukon
Has anyone got torque specs for installing the 2000 4l60e to the 5.3L SLT engine, with np246 t/case. So many variations in specs out there .
transmission to the engine.
Flywheel to torque converter
Exhaust Manifold Bolts
heat shield to transmission.
transmission rear mount.
transmission cross member
Driveshaft- rear axle
Starter to engine
Thanks guys
i havent used a torque wrench on these items ever as i do trans R&R for a living and just use my impact guns. 3/8" drive for everything except for the trans to the engine. and for that i use my 1/2" gun with a 3 ft extension. i zip it flush and give it a couple short bursts.
as far as the rear drive shaft, if its steel i use the 3/8" gun, if its aluminum, i tighten it by hand.
the heat shield that goes on the passenger side of the case, i just tighten by hand as well. maybe 15-20 ft lbs.
after 20+ years, i dont have anything come loose on me or do i have a problem with removal in case the trans has had to come back out
