Has anyone had problem with Dupont Hot Rod Black Paint?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2012, 09:54 AM
Hi, I am new to the site so please excuse me for not doing something or doing too much. Here goes.
A friend of mine has painted a car with DuPont Hot Rod Black (99K) and Flat Clear (2370S) and in the seams it appears to have some bubbles or is lifting away from the body, not many, just here and there. This has never happened before to him. Always used DuPont. 1st time using the above paint 99K & 2370S clear. Can anyone enlighten us? Has anyone used this paint & had the same problem?? Looking forward to seeing if anyone had the same problem.
Old 06-19-2012, 02:50 PM
This is certainly not something limited to that particular paint and clear. But if those crevices aren't perfectly clean the paint being applied over it can shrink up as it flashes it solvents and pull up off the bottom. Or, it isn't the paint or clear at all at fault but the previous primer that was applied and it was applied over something questionable and when the paint and clear solvents get into the primer a little (if it isn't fully insoluable as many undercoats are) it can lift up off.
But it is likely simply too much material applied and it is shrinking up.
Old 06-21-2012, 06:16 AM
deadbodyman's Avatar
Wiki Edits: 11
It could also be water and/oil in the air supply...check the compressor and filters ,make sure its all drained before you start...and those tiny little oilless ones are the worst they get so hot they shoot water out everywhere.
Hot rod black paint care ah21283 Hotrodding Basics 5 12-06-2011 09:09 PM
Hot Rod Black Paint fatrat Body - Exterior 15 07-02-2011 01:45 PM
Brand name Hot rod black paint 62440 Body - Exterior 7 08-23-2010 12:21 AM
What do you think of the (flat) "hot rod black" paint appearing on new supercars etc. Ripped General Rodding Tech 5 07-30-2010 07:33 PM
Hot Rod Flatz paint problem Bob 1743 Body - Exterior 1 05-14-2007 05:20 AM
