Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Has anyone here done an Electric Parking Brake?
Old 10-18-2008, 11:10 PM
matt167 matt167 is offline
Wiki Edits: 31
actully, ford did put a warning sticker on the dash for rollaway cars.. says to set Ebrake and fully engauge in park.. I still have the 1 on my Falcon.. as I understand it was part of a recall....
of course the easy soloution to applying the E brake fully is to push the brake pedal down b4 pulling the E brake lever and it will pull much easier, and of course, the cables need adustment too.. pull the handle 1/2 way out, adjust cable until it fully engages the brakes, then release to make sure they free instantly.... also, the ford system does not activate in reverse, so keep that in mind too
