Has anyone installed a Rosewood steering wheel on a 69 Camaro.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-11-2008, 09:59 AM
I am installing the steering wheel on a tilt column. I got the entire kit and it didn't come with instructions. I need to know how far down the shaft is the adapter supposed to go and how tight the nut is supposed to be? When I tighten the nut against the adapter it seems to get get very tight (around 20 ft/lbs tight) with the teeth of the shaft barely inside the teeth of the adapter.
Old 03-11-2008, 12:26 PM
re: rosewood
Hi Maybe a stupid ? but did you make sure that the splines match up on the column to adapter ? lt should go down until you can see the splines coming threw the adapter plate !TROY
Old 03-11-2008, 12:31 PM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
I have a 69 Comfort Grip in the 59-----with an Ididit column
The adaptor slipped right on---------in fact I even had to tighten the steering wheel a few days ago, as it had loosened up some.
Old 03-13-2008, 10:00 AM
adapter...
This adapter I have seems to only slide down a little ways before it gets snugg. It gets tight before the teeth meet.
Old 03-13-2008, 10:15 AM
REPRODUCTION adapter NO DOUBT
The originals slide down nicely and full spline.
Old 03-13-2008, 10:30 AM
streetrodderbn's Avatar
Certifiable Streetrodder
what adapter do you have? are we talking about a factory wheel? is the adapter for a tilt column? what steering column are you using? any pictures?
Old 03-13-2008, 08:24 PM
adapter....
I will try to get some pictures tomorrow. It is an after market adapter that came in a mounting kit from Ricks. It is a tilt column and the kit is marked that it is for a tilt. I put it on and tighten nut down to check it again. I went just hand tight (about 20 ft/lbs). The teeth are engaging by about 1/8 inch at this tightness. I know the factory manual says to tighten nut to 30 to 35 ft/lbs! This brings up another question. Is there supposed to be a washer under nut or does it tight against the adapter without one?
Old 03-14-2008, 08:52 AM
some factory wheels use a washer, if it's an aluminum adapter, I would use a washer so the nut won't dig into the aluminum, and tighten the nut w/ a torque wrench. I usually use the blue locktite on the threads.
Old 03-16-2008, 01:17 PM
Thanks...
Thanks to all! I got it. I found a great picture of the install in the Factory service manual.
69 Camaro georgejobarton Suspension - Brakes - Steering 6 11-23-2007 01:54 PM
Will power steering box from 82 camaro work in 67 el camino dave2148 Suspension - Brakes - Steering 7 09-05-2005 08:37 PM
Putting on new air bag steering wheel on a older steering collumn. CruisingRam Interior 10 12-20-2004 03:34 AM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 06:54 AM
69 Camaro, power steering? FiefSS Suspension - Brakes - Steering 1 01-03-2003 12:30 PM
