are you talking about the valve or the sleeve at the end? the sleeve is gonna be a bit snug. the valve inside that sleeve as long as its free is going to be fine. you dont want any "freeplay" of the sleeve in the bore as that will allow too much fluid to get past and could possibly end up not taking care of the pwm circuit that is known for the p1870 dtc which is what that kit is for.
Thanks tnsmith10 for the reply.
Yes I mean the regulator valve sleeve is very snug, so that is good. the regulator valve inside is no problem, as it is housed by the sleeve. The first valve to go in, the isolator valve, is a tight fit. when lubricated it strokes in its bore, but with no play whatsoever, is that OK or will that be a problem when the tranny is running?
the main reason for the kit is to fix the p1870 dtc, what causes the code is the regulator valve wears in the bore of the sleeve and creates too much leakage past the valve. the sonnax kit is great, but in my personal opinion, the pwm circuit is a waste to have in this trans till they (gm) fix the problem that they created. i just put a check ball on each side of the spring and put it back together. eliminate all that movement that creates the wear. it basically turns the pwm circuit back into a on/off type lock up apply. |
Thanks for that clarification.
Tearing down much or this GM, tranny included, i have seen many design flaws that could be improved on. As they saying goes: "Day don't build dem like day ustoo!" |
ill agree, i liked the simplicity of the older hydraulic controlled transmissions, diagnostics were pretty simple back then, not to mention with the lack of electronics, cheaper too.
i have a 97 blazer that works, but this spring the tcc has quit locking when warm... works when cold, then starts a bit of a slip, then wont lock......
i was interested in the springs and check balls, can you elaborate on that? tnx |
| P1870 - TransGo or Sonnax Kits ??? | bobbyv | Transmission - Rearend | 8 | 04-04-2010 02:31 PM |
| Valve Spring installed height (Beehive) | 70bird | Engine | 2 | 06-17-2008 09:19 PM |
| Valve Spring installed height | 70bird | Engine | 2 | 04-15-2007 11:44 AM |
| Valve spring installed height | 72 Chevy Nova | Engine | 11 | 02-13-2007 12:16 PM |
| valve spring installed height? | Kramer | Engine | 5 | 05-16-2003 04:36 PM |
