Has anyone replaced the door skins on a 69 Camaro? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 05-20-2009, 09:43 PM
deadbodyman's Avatar
Wiki Edits: 11
Vince,I'm curious,Did you have to remove them?I might just know a trick to easier removal
  #32 (permalink)
Old 05-20-2009, 11:06 PM
Originally Posted by 302 Z28
I had a 90 model Chevy full size truck and they were glued on.
Vince
Vince, I am sorry, but they are not glued on. They are plug welded on with four welds per hinge. I know them too well having changed them before. They are without a doubt the worst single mistake in design GM ever did. They fell on their face and broke their nose on that one.
To install this kit you have to drill out the GIANT plug welds from the factory. They are about as big as a dime and VERY thick with a large lump of metal on the back side. On the outside you don't see much as they kept it pretty flush. But you need to drill a 5/16" hole thru the middle of the weld and then sticking a flat ended rotary file into the hole and enlarge the hole on the top side cutting the weld off the hinge only. You then remove the hinge. At that point you take that wire device you see in the photo and screw one of the studs on it. You stick the other end of the wire up thru the hole in the cowl where the door power window wiring comes out. You have to feed this wire up thru one of the holes where you drilled out the welds! You then pull this wire until the end of the stud sticks thru the hole and you unscrew the wire off it without letting it drop back thru the hole into the cowl. You put a nut on it and tighten it up pulling the stud into the hole onto it's knuraled section so it will stay in the hole. You do this to all four studs and then bolt the hinge on. ONE BIG PROBLEM, remember the large glob of metal I said was on the back side of the weld? How in the hell can this stud sit flush there? It CAN'T , that's how. So the stud won't stay there, and won't stop spinning when you tighten the nut!
I will do ANYTHING before I change another. I'll weld up the hole for the pin and redrill it, I will buy the hinge kit and cut a section off and weld it to the original, ANYTHING before I ever change one of those things again!
  #33 (permalink)
Old 05-20-2009, 11:07 PM
Originally Posted by deadbodyman
certainly!!!! Everything hinges on a good bond ,doesnt it ?
LOLOLOLOL, no kidding, LOLOOLOLOLOLOL, you are a clever man my friend.
  #34 (permalink)
Old 05-21-2009, 10:15 AM
Wiki Edits: 11
those chevy trucks are welded on,they use a caulking around the hinge that looks like its glued. Brian,didn't I warn you about my off sence of humor? Usually no one appreciates it or finds me funny. When you say its the worst design ever I'm with you,I'll never replace another one ether ,I've even cut the ears off and moved them to get an adjustment I need ,no fun at all.
  #35 (permalink)
Old 05-26-2009, 02:15 PM
We have one of these trucks in the shop getting a door skin so I was able to take a photo of the welds. This is the hinge on the door, but the cowl side is exactly the same.
  #36 (permalink)
Old 05-26-2009, 03:08 PM
Race The Truck
Last journal entry: Son's Truck
I welded the top hole on my 89 truck worked out great. Took me an hour
I want the name of the GM guy who thought this was a good Idea. Just bend and ajust simple . 90.00 for a hinge
Craig
  #37 (permalink)
Old 05-26-2009, 09:30 PM
Wiki Edits: 11
replacing pins and bushings is a common repair but this design makes it kinda tough,even for the pros,especially if the truck has full power with a giant wire harness to deal with.this is a perfect example of why you would put on a skin with the inner shell on,their very tough to adjust afterwards.adheasives are perfect for this application
one piece fiberglass front end for 69 camaro??? chevyelc81 Hotrodding Basics 8 05-10-2011 12:39 AM
The first 69 Camaro built for competitive drifting ChevelleSS_LS6 Hotrodders' Lounge 20 11-16-2005 07:43 PM
'36 P/U, 69 Camaro subrame engine help!!! Apathy93Z Engine 1 12-08-2004 07:54 AM
i want too change a 69 firebird intoo a 69 camaro traviss10_999 Introduce Yourself 1 07-03-2004 01:17 PM
69 Camaro Big Block Underhood Photos?? EricTopless68 Camaro Engine 4 03-10-2004 07:03 PM
