has anyone tried those add-on brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2009, 02:07 PM
awert's Avatar
58/58
I'm converting the front breaks of my 58 ford, from drum to disk, I know about the Monark , montego, or torino, spindles, Yea, try to find em at a decent price.....I found a URL that makes a bracket that bolts onto the original spindles, which allow you to use ford Ranger rotors and chev S-10 pads, the rotors are 10.25" (big enough?????) At $150, for the set.....any thoughts on them things?????Thanks also does anybody know where i can get a set of bushings for the front suspension.......
Old 11-03-2009, 04:17 PM
Wiki Edits: 31
it would help to know the company your talking about. If Scarebird, there good stuff. they don't list somthing unless it's good.. everythings tested b4 they offer it for sale
Old 11-03-2009, 05:10 PM
awert's Avatar
58/58
yes it was scarebird, I'm wondering if the 10" rotor will be sufficient.. It seems cheaper in the long run, cuz with the monarck and others of the late 70' I would assume the rotors and cal. would be getting hard to find. That and there NOT a direct bolt up, More $$$ to set them up right......
Ford Expedition Brakes Augusto Suspension - Brakes - Steering 33 03-05-2012 05:37 AM
Manual disc brakes galaxieguy3 Suspension - Brakes - Steering 6 07-21-2009 06:49 PM
Need Help With My Brakes S10 Racer Suspension - Brakes - Steering 4 01-18-2009 02:00 PM
Thinking about swapping rears: Will getting the brakes to work be easy? Dirk Squarejaw Suspension - Brakes - Steering 3 06-26-2006 05:38 PM
Drum Brakes WildOne Introduce Yourself 1 12-03-2004 09:41 PM
