Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Has anyone used a 3M Bristle Disk
Old 12-14-2009, 11:47 AM
Hot Rod Mike Hot Rod Mike is offline
3M bristle discs/Roloc discs
While I have used these to strip paint in some areas of a vehicle, I think there are other means to do so @ a lower cost. However, I have used these in the past to clean up an area where I might be welding, to eliminate any rust or minor corrosion or other surface abnormalities. They are helpful also to get the temps of the sheet metal up so that the 1st welds are not on "cold metal". Even thought my garage is heated, the metal in the winter time is cold to the touch, so I just run these around a little on the area to be welded to warm up the metal.
