Has anyone used (Or heard of) the Astro HTE gun? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2010, 07:43 PM
I'm still debating between the EVO, and the other Astro called the HTE.
A lot of people like the EVO, but they say it's really slow. I'm a real amateur, and will only be painting 1 car. Is it so slow you can't do a full car (Will the clear flash before I get around to it again? And if so, is that bad? I hear it is).
On the other hand, the HTE I assume is quicker, but I can't for the life of me find anyone using it, anywhere.. THe Euro HTE I believe it's called.
Thanks guys
Old 09-09-2010, 08:58 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
You may wish to contact them directly..
http://www.astrotools.com/default.aspx?sec_store_sn=60&
I believe the EVO needs less air than the HTE..any way I have found the ASTRO tools to be a good option for the painter on a budget..
Sam
Old 09-09-2010, 03:35 PM
Just trying to decide between the two. I can't seem to find anything about the HTE. I have a 60 gallon 15.5cfm at 90psi compressor, so can I venture into the HTE, or should I stick with the EVO do you think?
Old 09-10-2010, 07:13 AM
35WINDOW's Avatar
Last journal entry: Engine!
I'm an amateur myself, and I have 3 EVO4014's and one EVO 4018-they will never be confused with an Iwata (not even in the same league), but for my painting projects they have worked very well-I would not hesitate to shoot a complete with it. Is it an air hog? I don't think so, and I have a slightly larger compressor than yours and it keeps up very easily. As with any Gun it has to be adjusted properly. Maybe it's just me, but I would suggest either shooting Epoxy on your Car to get the feel for it, or practicing on something before you do your actual Painting-I had some boo-boo's understanding the air-travel speed-fluid relationship, but after I figured that out it looked great.
Remember what BarryK says-"A simple formula to remember is orange peel is fluid adjustment and run control is an air pressure adjustment. "
Read this BEFORE you pull the trigger on any gun, it will help-
http://www.southernpolyurethanes.com...your%20gun.htm
Are there better Guns out there? You betcha-
Spot weld driller Shoot out! MARTINSR Body - Exterior 5 05-30-2005 05:46 PM
New primer gun IROC100 Body - Exterior 14 05-04-2005 01:17 PM
1 "better" gun vs. 2 "cheap" guns? nosaj122081 Body - Exterior 14 04-13-2005 09:23 AM
Want a new gun Rick WI Body - Exterior 3 03-20-2005 08:18 PM
paint gun deuce_454 Body - Exterior 4 02-04-2004 04:08 PM
