-   -   Has anyone used Xtreme Flat Finish? (http://www.hotrodders.com/forum/has-anyone-used-xtreme-flat-finish-217422.html)
piercetdg 03-27-2012 03:18 PM
The full name is Xtreme Original KlearKote Flat Finish 2.1 VOC
It's a clear coat that makes base coat, flat. I just sprayed it 4 hours ago on a 2 test panels. One I painted like I normally would and got a slightly blacker look then I'm used to. The other panel I did 50% overlap instead of 70 and raised my hand 2 inches. It looked really dry but the texture is too much, it was kind of flat though.
It seems like I'm using this wrong or does this go flatter over time?
Thank you.
inkfreak1976 04-04-2012 10:40 PM
i used this product and in my opioin it sucks, my job came out the same way after test panels thinking i dialed in my gun, and tech. the finish came out patchy, tiger striped, and glossy in other areas. unless you have a vast number of years painting and a sata jet, i wouldnt recomend spraying this, i ended up haveing to sand and reclear glossy this time. came out like glass.
you could try like a med solids clear to get the flat look, or i think they also have a satin style depending on the paint your useing. once i even used a med solids clear and basicly just gave it many tack coats. or dry spray. since your not wet sanding it or buffing it. even if you did with the pre mixed it would no longer be flat. the job looked really good and consistant better than the product that your asking about. do some research before spraying. its a real pain in the butt. good luck if you get it to work let me know how you got it to lay down right.
piercetdg 04-05-2012 03:52 PM
I did get it to work and lay down right but my customer prefers the slightly glossy flat look. But yeah it looks exactly like those flat black vinyl wrapped cars, it's like a painted molding, 100% no gloss.
The two secrets are that you need to shake the clear for an incredibly long time, if you're doing a whole car maybe get a friend to shake it for literally 2 minutes. Once done, it'll come out looking like lemonade, might even have a few bubbles. Now when you put it on the car, put it exactly like you would a wet clear and you will see orange peel and you will see foggy stripes. Turn the heat up really high and let it bake for an hour and you'll see that it totally changes. No more orange peel texture and absolutely no gloss and most importantly, no foggy stripes.
If you want to have the colour a little brighter like how some matt black paint jobs look grey, pull the gun back an inch or two.
inkfreak1976 04-10-2012 01:52 AM
im a garage painter i donet have a heat dryer, wish i did. but for me the final resault came out terrible ill never use it again. its just to hard to hope that you have the right results. with my job i ended up haveing to strip down the flat clear and re coat the color then i shot over with high solids clear. it looks better any ways in my opinion and my client loves the glossy look, bad thing is i was doing just a raceing stripe in the flat and i didnt strip all the way to the edge so when i cleared over it ive got a small edge. ive wet sanded over it with 15,2g and 3g grit, and now im getting ready to buff, do i need to tape off those lines or should i be ok.
piercetdg 04-10-2012 10:56 AM
You should buy a piece of 1x2 foot welding metal and try shooting that. But the most important part is shaking for 2 minutes, not 10 seconds, not 30 and not 1 minute, but 2 minutes. It shouldn't be easy to do. Then spray it like you would anything else.
I'm not sure what you mean about you fixing the stripes. What I would of done is feather out the edge of the stripe, sand everything with 1000, spray base on the stripes, reclear the entire panel.
inkfreak1976 04-10-2012 02:42 PM
ok im sorry i might have been a bit confusing with my last post,
what i ment to say was that, i had origanaly sprayed the flat clear on just my grapics witch is a raceing stripe, ( black with flat clear) the flat clear came out heavily tiger striped and inconsistant texture some came out nice and smooth and then some with heavy orange peel. i sprayed 4 coats to try and smooth out the clear and make consistant with no luck. the person that im painting the car for was very unhappy with the result and decidid to go with the same clear on the stripes as the rest of the car.
the car after epoxy sealer was based then cleared with 2 coats of clear then wet sanded at 600 grit, grapixs applied then i sprayed the flat clear, with terrible results. i then wet sanded the grapixs down with 600 grit. i didnt break threw so i didnt have to reapplie the base, i then sprayed the whole car with 4 heavy coats of high solids clear. waited a week then wet sanded starting at 1500 then to 2000 then to 3000 grit. with nice smooth results.
the graphixs on the edges it can be felt almost as if i had placed a decal then cleared over it, i did sand all three grits over the the edges of the grapixs but only litely,
im now at the buffing stage and im unsure how to go about buffing over the graphixs with the slightly raised edge. do i tape the edges then hand compound the edges or should i just go about buffing and hope i dont tear into the base or lift the edge. i normaly dont do much buffing on my jobs, i have a guy that does it for me. but he is on vaction and wont be back before i have to delever the car. so i have to do the buffing my self, ive buffed before but mainly on solid color cars none with grapixs and im unsure how to procede with this stage.
piercetdg 04-10-2012 02:51 PM
Oh so everything is now sanded and finished with 3000? I think you're right to be cautious about edges that come out. It's a good idea to hand compound those to be extra safe. I did a spot repair a few weeks ago and I burned through the 2 day old clear coat with a DA, which is a heck of a lot safer than a rotary buffer. But if you got to buff the entire panel then yeah it would make sense to tape the edges that stick out.
