Has spark & turns but won't start (won't even fire) - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2011, 07:31 PM
Hello -
Engine turns over but never fires.
Engine is a 350 sbc with edelbrock intake and dual edelbrock fours. MSD electric distributor and MSD blaster coil. Has sat in attached garage over winter - past 4.5 months. Put plenty of Stabil in last year and ran car for a while afterward. Have done nothing - no adjustments on engine since storing. Started fine last Fall.
Checked #1 cylinder spark plug and it's firing/sparking. Carbs are pumping fuel - I can see this in the carbs, fuel pressure gauge reads positively and spark plugs all have some gas on them and smell like fuel (after so much trying to start).
I don't know what else to try as I have always thought fuel + spark should at least fire and try to start. At this point my next step is shooting carb cleaner and starting fluid down the carb.
Thoughts? Suggestions?
Thanks!
Old 04-10-2011, 08:41 PM
You could try this
Try pulling all the spark plugs and give each cylinder 2 or 3 squirts of oil. You may have washed down the cylinder walls and don't have enough compression to fire up. Might not hurt to replace the plugs also if they are really wet.
Old 04-12-2011, 07:50 PM
Plugs were fouled a bit. Just replaced them and increased the gap a bit from where the old ones were at as they were at about the minimum recommended. Combined with blowing out the cylinders from probably flooding it the first attempt, it started up better than last year.
Thanks!
installed starter, turns over but will start Huskie007 Electrical 1 04-09-2011 06:56 PM
Engines turns over, but won't start Croz Electrical 8 07-18-2010 03:09 AM
Car Turns Over But Wont Start DTL504 Engine 19 12-27-2009 07:58 AM
'68 chevelle; 350 turns over but won't start servant70131 Engine 3 02-03-2003 04:56 PM
Engine turns over but will not start?? Jim Weeks Engine 13 04-06-2002 11:18 AM
