Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hatchback trim trouble
Old 07-19-2013, 01:15 PM
HotRodMan HotRodMan is offline
I am working on a 1973 Vega station wagon with the rear lift door. I had to remove the glass, trim, and gasket on that rear hatchback to clean out all the rust and paint the car. I am in the process of re- installing the outside trim around the glass. The little metal clips that held the trim in place have all rusted away and fallen apart, and I can not find replacements anywhere.
Anyone know what to do in this situation? Should I try to use silicone caulk and glue the existing trim in place, or is there some type of flexible trim I could substitute in its place that would be better? All the angles to the trim are sharp. Thanks
