Have a 1950 F-1 ford p/u and want to change the frame to something later model - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2012, 05:42 PM
Hello, could you recommend a specific frame I can put my 1950 ford 1/2 ton p/u on that will allow me to drop with air bags Perferably a ford chasis. I am open to a car or truck chasis. which ever you reccomend. Thank you.
Old 01-14-2012, 11:23 PM
IMHO frame swaps are a lot of work without much benefit.
Lots of guys like the S10's because they share some suspension parts with certain mid-size GM cars. I have always preferred to see guys use the frame they have and modify it as needed. Either way it's a ton of work best tackled by those who lots of time, plenty of equipment and a shop where they can do a long term project.
The F-1 adapts to a Jag front suspension very easily... it's almost a bolt-on. But if all you want to do is lay frame then I guess maybe an S-10 frame is in your future.
You can graft on an S10 front clip fairly easily but you'll need good fabricating skills and the right welder and cutting tools.
I have seen MANY projects, car and truck, get abandoned after the owner toss's the original frame then attempts to make another work...
Good luck.
Old 01-15-2012, 07:05 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
I'am in the same boat. Got a f1 that needs the frame done and I think on this a mustang or jag. is the way to go and use old frame.
Old 01-16-2012, 05:18 AM
I agree about having the skills and equipment to do this job.It's alot of work.I am currently building a 48 F1 and I used a Chassis Engineering bolt on M11 susp.Very easy to install.Also using a TCI leaf spring rear.Good luck with your F1.
Old 01-31-2012, 05:17 PM
Last journal entry: On the Road again
1948 ford, I have one of these checkout my listing at richlin2
I installed a heidts ifs and use the oeiginal rear springs removing 4 leafs. Look at my site for pics
1931 model a ford frame. jwbarker7@comcast.ne Hotrodding Basics 7 08-12-2015 09:13 AM
frame for 1950 f1 ford truck what is the best one to use jtullock Suspension - Brakes - Steering 11 09-27-2013 06:44 PM
Frame Specs for a 1930 Ford Model A superduty50 General Rodding Tech 3 01-29-2006 12:05 PM
1950 ford frame swap squiggy2000 Suspension - Brakes - Steering 2 08-08-2005 07:02 AM
model a pu street rod buildup using ford ranger frame bjm1956 Introduce Yourself 1 08-12-2004 10:34 PM
