have 67 chevelle put motor back - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2012, 08:14 PM
i pulled motor to redo it and put it back in and have no juice to switch or head lights or anything . could it be a ground or am i missing a wire. ran fine before removed.
Old 03-04-2012, 08:25 PM
406 bug's Avatar
9.82 @ 139mph
Bat. ok???
Old 03-04-2012, 08:26 PM
Originally Posted by 406 bug
Bat. ok???
has new battery can touch the starter across and it cranks the motor but not with out crossing
Old 03-04-2012, 08:34 PM
If it's the original wiring it's possible (likely?) that the smaller wires that attach to the solenoid have become brittle with age and snapped. I've had Chevelles do this and the insulation looked fine but the wire inside was broken leaving me with an open circuit that I couldn't see. It would be one of the smaller wires on the large solenoid bolt, when you take it loose if it's really limp right at the terminal you'll see what I'm talking about.
Old 03-04-2012, 09:19 PM
406 bug's Avatar
9.82 @ 139mph
If you have power from the bat. to the starter, it could be that your missing (forgot to connect) the main feed (from the terminal at the starter to the electrical system)
Old 03-05-2012, 06:07 AM
Bryan59EC's Avatar
Car? Truck? Who Cares
Last journal entry: First week of December
There should be a little junction block near the battery on the passenger side.
Mounted on the core suppoet.
ALL power except the battey goes thru this.
So--you need the smaller red wire (part of the positive battery cable) connected to this.
These should be a single 12ga wire coming out of the original harness that alco connects to this block.
'66 chevelle back window DougMN Body - Exterior 2 06-23-2006 09:32 PM
what motor do i have in my chevelle?? joshv5.0 Engine 8 08-06-2005 02:22 PM
65 Chevelle Frame Back From Powdercoat, Narrowing details for Wally8. GMW Body - Exterior 3 08-17-2004 09:24 AM
GOT MY CHEVELLE BACK AT LAST! MYNAMEIZCARLOS Hotrodders' Lounge 12 02-09-2003 09:40 AM
motor back fire DESPERADO Engine 3 07-09-2002 03:26 PM
