Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Have any power washing tips?
Old 01-28-2006, 10:08 AM
predator carb guru's Avatar
predator carb guru predator carb guru is offline
Mark Goulette
one word of caution: try not to point the high pressure spray directly at or on any connectors in the engine compartment......you can get water in them and cause all kinds of problems that are difficult to find................i usually use castrol superclean and water at about a 50/50 mix and just use a hose and spray nozzle............simple green works well too.......
