Have any power washing tips? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2006, 05:53 PM
cboy's Avatar
Last journal entry: Finished
What tips and procedures do you have for power washing an engine compartment and the underside of a car?
Always learning...and sharing what I've learned.
Old 01-27-2006, 08:08 PM
copndoc3's Avatar
Retired Super Trooper
Last journal entry: The Uncommon Street Rod - Photoshoot
Raincoat, rainhat, boots and lots of towels. A creeper if your really brave to get the underside.
Old 01-28-2006, 06:16 AM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Is the vehicle drivable.? If it is. Is there a auto rustproofing company in your area.? They should be set up to power wash the underside. Explain what you are after, they may be willing to let you into the shop to inspect it before it is taken off the lift.
Many many years ago I worked for a rustproofing/detail shop, on occasion we would have someone who wanted what you are after. The owner was a hell of a nice guy and never turned anyone down.
Old 01-28-2006, 07:44 AM
cboy's Avatar
I have a power washer and a lift...what I'm interested in is what others have used for grease cutting (if anything other than the water spray) and what special precautions people take (such as bagging the carb, alt, distributer, etc). Just tips on how best to get the engine compartment cleaned up in the easiest way possible way without creating any damage. Or even if folks have strong recommendations against using a power washer at all under the hood.
Old 01-28-2006, 11:08 AM
predator carb guru's Avatar
Mark Goulette
one word of caution: try not to point the high pressure spray directly at or on any connectors in the engine compartment......you can get water in them and cause all kinds of problems that are difficult to find................i usually use castrol superclean and water at about a 50/50 mix and just use a hose and spray nozzle............simple green works well too.......
Old 01-28-2006, 01:44 PM
montea's Avatar
tryn to learn
i put plastic grocery bags over the air filter, battery, and alternator. spray down everything with Gunk heavy duty engine degreaser and/or simple green, let soak for 10 mins rinse off and repeat on greasey areas untill clean.
Old 01-28-2006, 02:23 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
Definitely use the plastic bags any where water could be a problem. I twist tie them or tie wrap them on. You never know when the spray will blow them off. Before you start run your engine and get it hot as the grease and oil removes easier. Spray it down with degreaser and let stand for at least ten minutes. Use hot water in your pressure washer if possible. Use compressed air to blow excess water off, wipe off any water stains and then start your engine to completely dry it. By the way love your journal and the new index!!
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Old 01-30-2006, 09:03 PM
1ownerT's Avatar
Wiki Edits: 4
My suggestion to take it to someone comes from, how much of a mess do you want to make in your shop.? I was the one to do the power washing/steam cleaning at the shop I worked in. It depends on how much grease and grime you need to remove, you can end up with the crap everywhere.
I clean everything I buy, usually at a car wash, usually late at night. I take a set of drive on ramps to get either end up in the air. Soak it with the degreaser of choice, the Castrol mentioned is a good one. I have also used one called Purple Power, I am not sure who makes it. I don't think much of Simple Green, it is a little pricey and seems to need to be scrubbed to make it work.
I clean the engine on my daily drivers 3 to 4 times a year, I do not spray directly on the distributor or the alternator and if it is carbed I use a towel to cover the carb. Maybe I have been lucky but I have never ended up with any moisture problems. If you want the engine compartment to look like new after you clean it use some no touch tire cleaner. A two piece rain suit, safety glasses and a hat will come in handy.
Unusual Power Steering Conversion Lars Sorensen Suspension - Brakes - Steering 17 05-25-2004 03:05 PM
Power Valves Ktaves1971 Engine 1 05-11-2004 08:35 PM
Replace arm strong steering to power in your 51 to 54 Chevy car Michael Bryan Suspension - Brakes - Steering 3 05-08-2004 10:50 AM
68 power steering burner Suspension - Brakes - Steering 5 04-06-2004 09:20 PM
power brakes and power steering on a '63 impala SS Benni520 Hotrodders' Lounge 2 10-14-2002 10:49 PM
