If the knock is very low and metallic it's a bearing.
If the knock is high and high pitched it's valves. Piston slap is somewhere in between. Run a compression check, that'll tell you if you have bent valves. My guess is it isn't. Bent valves will cause a loss of compression as well as a miss. |
there are a few other possibilites. they are not as common, but can happen.
when switching to newer or aftermarket heads sometimes the rockers will actually slightly touch the valve covers. i just had this, a thicker gasket is enough to correct it. it sounds exactly like a loose rod slapping the crank. if the distributor has been pulled, check to make sure the oil pump drive rod is oriented right and distributor is seated on the intake properly. definately do the compression check? a stroker has a lot less clearance in there. you should be okay though since you did not remove the timing chain! i know you said you had the heads off, what else did you change? you said they were removed to get them checked! what was the problem to get them checked, that could have to do with it hope this helps, 31 |
The 383 was consuming oil this is why I had the heads checked and came out the exhaust guides were gone so they replaced them and cleaned them up.
I took off the oil pan to recuperate a small dried up bit of RTV that had fallen down the opened motor while working on it...replaced the pan with a new gasket..I had the opportunity then to see all the clearance work done on the block to accomodate the 383 crank. and rod bolts. Took off the water pump trying to replace it with a new aftermarket one wich wasn't an exact fit..replaced the old pump. When you mentionned the distributor shaft in its right orientation...I don't understand it...isn't it only one way to engage that dist. shaft on top the oil pump drive?? The rockers/studs/heads/springs are the same as before and there is no signs of any hitting the valve covers. Now have I spun a bearing?? That engine did not rotate for 3-4 months ..winter time and I've primed the oil pump with a Moroso priming shaft before firing it up and had the pressure coming up to around 50 psi for 5-10 minutes...this should have had the crank. bearings oily enough?? Spark knocking?? This is old gaz (6 months old) High octane but I had a storage additive to it before storing time... don't know for sure but it smells High dollar repairs this time! So much work and money spent it becomes a really bummer situation. Ronald. Thinking about what wrong things I might have done...While the oil pan off I hand-turned the engine few times..could this have shot one bearing?? thank you, Ronald. Last edited by TVR383; 05-11-2004 at 10:29 AM. |
especially since you primed it, that is farther than i would have gone. the gas may be a lttile old, but i can't imagine it would produce the sounds you are hearing. the oil rod has a slot, the distributor has a male piece that slides in, it can be either direction. if the distributor dropped all the way in on the intake, you are okay. i only mention this cause i have had distributors with oil pump bind and they won't seat right. this after some type block squaring or decking though Quote:
have you lost any tools lately, hopefully you did not drop anything else down in the motor. like the sealant! do the new bronze guides show any wear? 31 |
