have a look, can this be fixed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2004, 05:19 AM
mikeweyman's Avatar
Last journal entry: 2 years later
this is the tach circuit from my 75 stingray, can this be repaired?will it likely happen again?what would cause this?any input would be greatly appreciated. mike
Name:	tach circuit.jpg
Old 02-06-2004, 10:21 AM
302 Z28's Avatar
Sure it can be repaired, just solder a wire from either sides of the burnt portion on good copper. Now as to finding what caused it, that is anyones guess. Not knowing what exactly that circuit does and not having a circuit diagram, well it's a toss up.
Vince
Old 02-06-2004, 12:19 PM
mikeweyman's Avatar
it runs the tachometer on my 75 stingray,it's located inside the tach itself.by what i hear it just happens,no reason, but it is the cause of 98%of all these tach failures. this is the only one i've seen that wasn't totally fried.
I've posted both front and back views if they're any help.
Name:	full tach front.jpg
Old 02-06-2004, 12:24 PM
mikeweyman's Avatar
hheres the back
Name:	full tah circuit bott.jpg
Old 02-06-2004, 12:27 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Looks like it is just the one open circuit. Impossible to tell if any of the components is fried too. Easy to test, just solder on a jumper wire and try it. If it works, great and you save spending the national debt @ Chevy for a replacement, if not nothing lost except a month's income to GM!
Old 02-07-2004, 10:07 AM
mikeweyman's Avatar
thanks guys, i'll find out soon.
