have mercy im new - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-24-2007, 03:53 PM
have mercy im new
Hi guys,
okay here goes...i have 41 nash coupe that i cut the unibay from (or what was left of it) and reworked the mid and rear half of a s10 chassis for and i have added just unerd 4 ft of 2x3 rect tubing to...mounted the springs and i am working on the steering..the front suspension is out of a 64 ford f100 with machined hubs from a chevy 1/2 ton with disc's...now my question is what do you use as a travel limeter for the straight axle to keep in place when you turn going up hill or down...do I really just rely on the leaf springs and blocks or do I have to add a "hair pin" of sorts to this set up..any help would be great and i will post some pic's for ya guys as I learn this site..i am a member of the ol skool rodz forum to and have some pic's on there forums if you get anxious
Old 10-24-2007, 04:46 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
I assume that you have two paralell leaf springs if so I do not think you need any hair pins or anything. The truck that used your set up did not need them , so they should not be needed now.
Old 10-25-2007, 02:04 PM
good news
Hi again henry, thanks i assumed it didnt but you know what they say about assumtion's....i was just a little worried about the rocking effect it will have...the trans is a 4 speed borg and wrner close ratio with a richmond rear axle with a set of 5:13's...lotta torque...i do have a big block chevy motor for it i built..but i ended up with a trans adapter and blower intake for a hemi 331-392 style...so the plan is to use a lil 331 hemi i found in indiand with a 8-53 blower i had refubished ....the hemi is already heavy..you think with the added weight of the blower and a manual trans action might be to much for a set of s10 springs?
Have mercy on this "newbie"! whitevette Introduce Yourself 5 06-15-2006 11:37 AM
The New Virtual Kustomz Thread! WakBordr7387 Hot Rod Art 419 04-04-2006 08:43 AM
Is this the end time? USA1 Hotrodders' Lounge 307 07-11-2005 07:25 PM
engine tuning need4speed2345 Engine 11 05-11-2004 05:31 PM
