Have an old school 350 in a 4.3 v6 truck. - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2011, 07:45 AM
I have a 4.3 V6 truck and put a old school 350 V8 in it. Have a few ???s Got it all down in the engine and hook up to the bell housing. Got the alternator wires. And the ground for the battery hooked up. Need to know what wires do I need to hook up to make it run. Right now there is no power what so ever. I have a HEI distributor. What wire hooks to that. And a lot of plugs and hook ups that I have no idea where they go. What do I need to make it run. If any body could reply to this would be great. If any body has any pictures so I can see what it looks like when it is all wired and hooked up. I know there is some body out there that has done this type of motor swap. All the input is helpful. Thanks for reading.
Old 01-08-2011, 02:37 PM
Well I did a Swap on my 1989 Chevy Pick up that is Kind of Like what you are doing . Mine started out with a 5.7 350 TBI EFI Set up and I went to a Mild Built 305 Gen 1 carburetor Engine . As for My HEI Feed Wire . I used the Red Ign on / Hot Wire that went to the Factory Ign Coil . My Truck runs much better now and gets better Mileage too .
http://www.activeboard.com/forum.spa...picID=37921405
Old 01-08-2011, 02:56 PM
Anything else do I need to hook up for power. Like I said no power. Battier have juice but you turn the key on and its dead.
Old 01-08-2011, 03:06 PM
All you need to Power that HEI is that Red wire of the Factory Coil Wiring . With the Key on Check for Power at that Wire . As for the Starter all the same Wires on the 4.3 Starter are Hooked up the same on the 350 Starter . Make sure all your Battery Cable Ends are Clean and making a Good connection .
Old 01-08-2011, 03:37 PM
Tango,Do you have a picture where it is and on how to hook it up.
Old school motor in new school chevy or pontiac Tryin2MakeIt Engine 4 01-31-2009 08:26 AM
Old school meets new school lilchev80 Engine 4 05-06-2008 10:06 PM
Old School With New School Scheme, Good Idea? inkster Hotrodding Basics 3 06-12-2006 08:17 PM
Another school shooting, this time it was at my son's school.. RetroJoe Off-Topic 6 03-18-2006 09:47 PM
what auto school after high school camino_man Hotrodders' Lounge 2 04-28-2005 09:02 PM
