have a Question about a power steering gear box - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2012, 09:08 PM
Hi Is there suppose to be any movement at all in the power steering gear box. When there is NO inner tie rods hooked up ???????
Old 07-15-2012, 08:23 AM
The steering boxes depending on manufactorer should only have about .040 slack at the most any more than that means the worm gears are worn you can rebuild it but for the price it cost it is much cheaper to go to a parts house like advanced,autozone, or napa and get a replacement they do have a core on them so bring the old one they run about 100 to 200 bucks for remaned units, if you rebuild it yourself and need the gears the gears run about the same price not including the seal kit and bearings.
Old 07-17-2012, 09:51 PM
steering gear box
k thanks so much
NEED - Power Steering Gear box Diagram Jcruzzzer Suspension - Brakes - Steering 2 06-29-2010 04:45 PM
Power Steering Gear box Jcruzzzer Introduce Yourself 1 06-22-2010 02:55 PM
Chevy 605 Power Steering Gear Box auto383 Suspension - Brakes - Steering 4 10-18-2007 09:13 AM
power steering box question hondachief21 Suspension - Brakes - Steering 1 06-06-2006 11:25 AM
power steering gear box question novadan Suspension - Brakes - Steering 2 05-25-2006 01:32 AM
