have a short and cant find it - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2003, 07:37 AM
Post have a short and cant find it
can any one help i got a short in my chevy pick up it drains out all my power from the battery i am haveing trubel finding whear the short is i checked my fuss and battery cabels can u tell me what to do next thanks
Old 05-22-2003, 11:15 AM
woodz428's Avatar
Troll Hunter
Arrow
You didn't mention anything about blowing fuses, so it must be before to that. I would look at the alternator, blown diodes can let current flow into the alternator when not running,draining the battery. Or, if it's not a short, just a power drain, you might put a ammeter on the positive side of the battery (between the battery and the cable), you shouldn't see any draw with switch off (clocks have a very low draw). If it is drawing disconnect one thing at a time to trace it. I had a vehicle with a similar problem (it was new) and after several return visits I found the trunk light switch had come loose letting the light stay on and was draining the battery as it set, of course with the trunk closed it wasn't seen and with it opened it appeared as normal. I actually found it when it came in again to have the drain checked and a wing installed, when I drilled the first hole, low and behold the light in the trunk shown through.
[ May 22, 2003: Message edited by: woodz428 ]</p>
Old 05-22-2003, 04:39 PM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Post
another thought be sure no lights are on you radio/cd player when there shouldn't be happened to mine draining battery,found like woodz428 said,place meter between pos.post and cable
