have th350 in g body. will 200r4 driveshaft work? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2011, 10:22 AM
MAKE EM STICK AND E.T'S QUICK
like it says i have an 81 monte carlo with a stout 327 and tcith350 its a short shaft version. i have the correctcrossmember and already notched it for true duals. will a 200r4 driveshaft be the same length?????
Old 07-25-2011, 12:38 PM
tnsmith10's Avatar
when will it rain???
the yoke will work but, without actually fitting the driveshaft, theres no way of telling as your not real specific on what the other driveshaft came out of. if it came out of the same model car, its possible that it will fit.
another thing you can do is to put the 2 driveshafts side by side and see if theyre the same length.
Old 07-25-2011, 09:47 PM
fast68's Avatar
likes chevy trucks & boobies
well.. FYI, the 2004r, and the th350 6" tailshaft (car and '69-72 truck length) are all the same length(right about 28.5" overall from bellhousing to the tail end)
and same driveshaft and yoke 27 spline
Old 07-25-2011, 09:49 PM
Thumpin455's Avatar
Ask me about Ethanol
Last journal entry: 65 GTO
You might have a problem with the length of the yoke, the 3004R needed a slightly longer yoke to engage the rear thrust bushing, without it the output shaft would flop around. It might be too long for the Th350, but try it and see, it still might work.
Old 07-25-2011, 10:14 PM
fast68's Avatar
possible but unlikely
unless the driveshaft is not from this model vehicle then it should be fine no issues so as long as about 2/3 or 3/4 of the yoke is engaged into the tailshaft with the car on the ground, on its rear tires, and at rest
if the th350 is the "short" 6" tail then youll be fine unless something else is wrong modified with the car as far as drivetrain location placement is concerned.
the 250 and the THM200C trannies are also the same length -are all right about 28.5" actual and overall length
the 250 trans looks identical to a 350 trans except it is missing two pan bolts so it has 11 instead of 13 of them, and alos on the side of the case is band adsjutment nut that the 350 trannies do not have
otherwise you cant tell by the outside a 250 trans from a 350 trans
just some random gm tranny info for fun
Old 07-25-2011, 10:19 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
I had an 80 Monte with a turbo 3.8l and a th350, the yoke and shaft worked when I switched out to a th200r4
Old 07-25-2011, 10:20 PM
fast68's Avatar
yep it would be plenty fine unless the car was/is modified in a manner noted above
have fun
Will my driveshaft work? zildjian4life218 Transmission - Rearend 26 07-24-2011 01:08 PM
200r4 swap for a th350 jpd37 Transmission - Rearend 13 04-16-2007 11:02 PM
200R4 to TH350 JohnyR17 Transmission - Rearend 4 10-18-2006 11:43 PM
Jetaway to a th350 or 200r4? flipp121 Transmission - Rearend 8 05-14-2005 02:08 PM
200R4 VS. 4L80 VS. 700R4 Vs TH350 WB72 Transmission - Rearend 16 11-26-2003 02:09 PM
