Have you ever reused a head gasket? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-25-2013, 02:21 PM
bigdog7373's Avatar
Of course it's fast
Don't think i would ever re-use a headgasket. Some of the newer motors have reusable gaskets, but they end up leaking over time so I don't know how reusable they really are. I wouldn't reuse any gaskets that are under pressure or hard to get to.
  #17 (permalink)
Old 03-25-2013, 07:27 PM
Originally Posted by Irelands child View Post
There are several levels of Fel-Pro gaskets. The ones I've reused are the HiPo Perma-Torque versions, i.e. Q1011-1 or -2(which I'm currently using). Their standard OEM level gaskets, i.e., Q9333Pt1 probably I would not reuse, are fairly inexpensive, though these are almost as good as the HiPo's for performance use without nitrous or supercharging
the gasket i reused was apart of a complete gasket rebuild kit that ws like 60 bux. idk what level it was though.
FEL Pro KS2646 Engine Kit Gasket Set | eBay i dont know about that one, it cost me like 59.99 though.
Should I use a gasket sealer on a .015 shim head gasket? Caprice Sleeper Engine 2 08-23-2012 08:46 AM
Head gasket thickness, Gasket or Shim? rollie715 Engine 6 04-25-2012 04:15 PM
Unable to separate head from block due to head gasket sealer Nostalgia Hotrodding Basics 18 02-02-2011 02:12 PM
Mr Gasket Ultraseal Head Gasket's 406 ss monte Engine 4 05-03-2008 09:19 PM
reused lifter, cam update DoubleVision Engine 5 02-09-2003 03:56 PM
