Having looked everywhere - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2009, 08:26 PM
slider in wa's Avatar
Slider in Wa.
I am askinfg for your help. Been through the knowledge base, and various outh site. Problem My 1988 1 ton will not accept GM Dually "BUD" rims. Same bolt and center hole pattern, they will not clear or fit over the brake drum. Please advise asap.
Thank you very much.
Ken
Old 07-13-2009, 04:09 PM
ASE Master Tech
don't think it uses budd wheels. they used the same rims front and rear i think and only used a standard lug nut with maybe a plate over the outside for the lug nut. just my experiences with only a couple older 1 ton trucks
Old 07-13-2009, 04:32 PM
Joe G's Avatar
You could get a dually axle, but then you would also have to relocate the shock mounts. DRW axles have the shocks staggered opposite of a SRW axle (example: one axle has left shock forward and right rearward, and the other is the opposite). I learned this the hard way.
Just looked weird 428ho Hotrodders' Lounge 1 10-14-2008 07:42 AM
what looked impossible for me to accomplish! chop52 Introduce Yourself 4 12-16-2006 10:05 PM
Looked at a 73 to-day Huge Gaps in Doors Auto-Part Hotrodders' Lounge 10 05-14-2005 12:50 PM
looked and no luck. nova subframe ? streetrodder31 Suspension - Brakes - Steering 7 06-21-2004 06:07 PM
What HotRodders.com looked like four years ago TooMany2count Hotrodders' Lounge 2 04-21-2004 08:28 AM
