Yup I agree it's either a temperature issue before and after spraying, old epoxy catalyst that has gone bad or a combination of the two. Your cleaning methods should have worked just fine and 120 grit scratches should have provided enough texture although 80 grit would have been better. I think it's time you shoot a test panel in good temperatures with good cure temps and see if the primer locks up and hardens good.
