Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Having problem with epoxy primer......
Old 06-06-2008, 06:41 AM
haism007 haism007 is offline
hello every one
SURFACE PREPARATION AND PAINTING INSTRUCTIONS:
STEP 1: Clean surface with soap and water to remove water soluble residue.
STEP 2: Clean surface with a wax and grease remover (PPG DX 330).
STEP 3: Hand sand hood to finished surface with 220 grit sand paper.
STEP 4: Clean surface with a wax and grease remover (PPG DX 330) and then apply a fast evaporating cleaner (PPG DX 220).
STEP 5: Apply the epoxy primer coat (PPG DP Series)*.
STEP 6: Clean surface with a wax and grease remover (PPG DX 330).
STEP 7: Lightly sand the surface with 220 grit sand paper.
STEP 8: Clean surface with a wax and grease remover (PPG DX 330) and then apply a fast evaporating cleaner (PPG DX 220).
STEP 9: Apply primer surfacer coat (PPG K36*.
STEP 10: Finish sand the surface with 400 grit sand paper, clean surface with a wax and grease remover (PPG DX 330) and then apply a fast evaporating cleaner (PPG DX 220).
STEP 11: Apply a coat of epoxy primer as a sealer (PPG DP Series)*. NOTE: To use the epoxy primer as a sealer, follow the mixing instructions provided by the manufacturer.
STEP 12: Apply the basecoat (PPG DBU Deltron)*.
STEP 13: Apply clearcoat (PPG DCU 2020)*.
STEP 14: Polish to desired finish.
