Having problems after rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-30-2007, 08:41 AM
roddinron's Avatar
I just had the tranny rebuilt by a local guy, who sort of does it "on the side". He assures me that he took no shortcuts, and that he replaced everything that needed replaced. It's a '95 Jeep Grand Cherokee (42rh I believe). I took it out and took it to him, then picked it up and put it back in myself.
It seems to work ok when it's cold, but after warm up, it starts doing strange things, like
not upshifting,
or when it does upshift sometimes it won't downshift.
Then when I stop, it feels like I've been rearended, there's a big bang and it shakes the whole Jeep!
Also sometimes after I stop, it seems as though it's stuck in high gear, it has very little power, and you can smell something burning, if you manually shift it to low or reverse then drive, it seems fine.
Also, sometimes, when i turn into a side street, then gas it, it just revs like it's in neutral, if i leave off the gas then back on, it's ok.
He said I probably didn't need to replace the T converter since it was replaced when the tranny was rebuilt the last time, before I bought the jeep.
I should mention also, that before I installed it, I noticed that the splines on the larger input shaft (outside one) seemed worn down, they weren't as sharp as the ones on the smaller inside shaft. I probably should have stopped and taken it back to him then, but I assumed he saw it and felt it was ok.
I was very careful to adjust the TV cable correctly, and used correct amount of the Chrysler recommended ATF4.
I haven't been able to contact the guy who rebuilt, and don't suppose I'll hear from him over the weekend. If any of you could give me some idea what's wrong with it, it will help me when I do get a hold of him.
Thanks in advance for any help you can offer.
Old 06-30-2007, 10:20 AM
I'd be taking it to him and let him drive it.
Old 06-30-2007, 01:33 PM
There is dirt or trash in govenor,did you clean or replace the trans cooler and lines?
Old 06-30-2007, 04:41 PM
roddinron's Avatar
Nope, I forgot to do that, I just spoke to him a little while ago and he said there's probably some dirt in it. He said to bring it in and he'll drop the valve body and check it. I sure hope that's all it is, I can't believe how hard this thing was banging! Funny thing is it works good when cold, it's just after it heats up.
Ford 351 Windsor Teardown & Rebuild 101 nightrain_rod Engine 10 07-20-2008 01:57 AM
Rebuild Kits 400smb_s10 Engine 4 06-04-2007 03:26 PM
Quadrajet Carb rebuild....parts interchange with another junk carb? Warrant Engine 2 07-31-2006 10:44 PM
problems with a 1986 Dodge 600 cesar9 Engine 2 11-03-2005 09:23 AM
25 Year-old Carb, rebuild or trash? Arcuden Engine 6 07-31-2005 08:42 PM
