Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - having problems with new 383 stroker motor
Old 05-28-2008, 10:02 AM
Gary 4866 Gary 4866 is offline
The motor is .060 over stock bore. I have found out that the pistons are half dished, so with 70 cc heads I must be real low on compression.
Would it help to buy some AFR 64 cc heads, and would I need to drop down on the cam or can I still run the same one.
