Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - having problems with new 383 stroker motor
Old 05-28-2008, 10:09 AM
Double_v23's Avatar
Double_v23 Double_v23 is offline
Horsepower Enthusiast
Last journal entry: Finished BMOD001FH
64cc heads would help, or you could have your heads angle milled to 64cc or less.
There are also things you can do with the heads gaskets, the thinnest ones I have found that are not steel shims are .021 compressed thickness.
We use these in some dirt track motors that see 8000 rpm. they are Gm Performance parts # 10105117.
