having trouble - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 05-15-2006, 11:10 PM
having trouble
rc
28 yo
mechanic
begginer restorer
1970 gmc p.u. timing
5.7L 350
replaced cam and lifters, replaced gears and chain...
2 timing marks on crank a triangle and a dot? which is right?
cam gear 1 dot. and cam has a pin so only one way to put it on.
step 1. i align dot and triangle...slow crank no start...checked tdc (not )
step 2. rerouted wires ...no start...
step 3. turned distributor 180" ......no start...
step 4. removed cam gear, turned crank until dot is at the top...
step 5. reinstalled cam gear, moved cam dot to crank dot (cam down crank up)
now have fast crank ....no start...
step 6. turned distrib. 180" again back to slow crank and still no start.
What am I not doing?
Yes there is fire and fuel...
R.C.
Old 05-15-2006, 11:36 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
having trouble
Welcome to the site rcpierced77. As this is an introduction forum you will get more exposure if you repost your question in the Engine forum. The experts there will be able to help you. Good luck with your project.
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
Kids and trouble Kevin45 Hotrodders' Lounge 15 02-20-2006 05:27 PM
Header Trouble 1980 Camaro w/AC william27103 Engine 3 11-14-2005 07:54 PM
chevrolet 327/350 starting trouble hk51 Introduce Yourself 0 07-10-2004 07:29 PM
c4 transmission trouble Steve W Transmission - Rearend 2 11-04-2001 08:04 PM
