Having trouble with my Consew226. - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2011, 04:43 PM
Hi,
I was surfing the web trying to find help on my Consew226. I found a post here but it was dated back last year..so anyway, I am taking a chance to see if any of y'all have one. I'm having problems with mine. Of course I bought it used and no, it didn't come with a manual...I've had it checked out, and it runs great for the repairman, certainly nothing new there... What is is doing is messing up on the bottom tension..making tight little loops on the upper thread..and it will break the upper thread...The machine is old...but heavy duty and will sew anything for the repairman...does anyone have any suggestions?
Thank you in advance,
Vivian
Old 05-14-2011, 06:50 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
This need to be in the interior section, a mod will come along and move it for you i am sure.
Cole
Old 05-14-2011, 11:09 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Originally Posted by Vivian2981
Hi,
Vivian
I have the same machine. If the machine sews great for the repairman then you are doing something wrong. The machine doesn't know who's running it. Is the thread straight across the bottom of the stitch? If so, either the bottom tension is too tight, or the top tension is too loose. Do you know how to loosen the bottom tension? There are two small screws that hold the spring steel tension to the side of the bobbin case. Loosening the front screw loosens the bottom tension. Is the machine threaded correctly? Here's a picture of how the machine should be threaded. It's especially important to have the thread seated firmly into the two tension disks on the top tension. If the thread isn't firmly seated you will have too little top tension which will cause stitches like you describe. Does the thread go through the thread guide just above the top of the needle? Are you installing the bobbin correctly? The thread should pull off the bobbin from right to left. Is your needle the right one for the machine (135X17) and installed correctly? The groove on the side of the needle should face left. Here is a link to the instruction manual for your machine:
CLICK HERE Also take a look at this manual for the Singer 111W machines, it has a great description of stitch problems: (your machine is a clone of the 111W, and has the same bobbin case, top tension, and attachments)CLICK HERE Unfortunately, neither of the two manuals is much help with other problems.
th 400 trouble 79el camino Transmission - Rearend 4 12-09-2009 06:26 PM
tbi trouble mitchw09 Engine 3 10-18-2009 11:09 PM
Someone Is In Trouble !!!!!!!! NEW INTERIORS Off-Topic 2 04-13-2008 08:55 PM
200-4r trouble help please 406 ss monte Transmission - Rearend 3 03-15-2005 12:53 AM
You know your in trouble when... 4 Jaw Chuck Hotrodders' Lounge 13 01-03-2004 06:35 PM
