If you can, try and find a wiring diagrams it will make everything easier. But look for something all four have in common. I would start at the hazard switch and follow the wire until you hit a relay. Check the relay. And if there is anything else all four lights have in common, check that.
I believe the hazards run through the turn signal switch on those cars. Check your route{easiest with a wiring diagram} I would suspect the switch is screwy.
Well, you guys were right, it was the switch. It's partially broken, so that it doesn't rock back and forth squarely on its axis, so it only depresses one set of contacts. I ordered a replacement for $70...yowzers!
Fix
Doc here,
Thanks For posting back (the expensive) Fix... May help the next guy... Doc
Aftermarket Solutions Electronic & Electrical Innovations |
| 94 Dodge Transmission Electronics problem? | Native Gearhead | Transmission - Rearend | 7 | 10-17-2006 10:00 PM |
| Problem batch loading larger images | cboy | Hotrodders Site Suggestions and Help | 10 | 03-23-2005 08:26 PM |
| *&%##*^#!! starter problem solved!!!! | 85 vette | Engine | 12 | 02-22-2005 08:12 AM |
| Newest Transmission problem | RObs71Nova | Transmission - Rearend | 4 | 01-30-2005 07:00 AM |
| Piston/valve interference problem | jameskirk1 | Engine | 12 | 12-03-2004 04:14 PM |
